DeanC
HELP: Compiling driver error, no /lib/modules/3.10.25+/build
Wed Jan 22, 2014 10:29 pm
I'm trying to compile a driver on my RPi running Raspbian. But I get the following error:
make: *** /lib/modules/3.10.25+/build: No such file or directory.  Stop.
make: *** [all] Error 2
Every normal (not optimized for RPi) version of Linux I have worked with has this directory. But I can't find it in Raspbian. Did this directory get moved somewhere else? How to I get access to it so I can compile my driver?
We 'idiot proofed' the world, and now it's full of idiots!
Re: HELP: Compiling driver error, no /lib/modules/3.10.25+/b
Wed Jan 22, 2014 10:54 pm
Can't you simply use
mkdir -p /lib/modules/3.10.25+/build
That /lib/modules/* stuff is all built by rpi-update
This is a doctor free zone.
DeanC
Thu Jan 23, 2014 1:51 am
DougieLawson wrote:Can't you simply use
I tried it and got the following error:
make[1]: Entering directory `/lib/modules/3.10.25+/build'
make[1]: *** No rule to make target `modules'.  Stop.
make[1]: Leaving directory `/lib/modules/3.10.25+/build'
make: *** [LINUX] Error 2
I just tried rpi-update, but but it changes the build to 3.10.27+, so I create the directory again and still get:
make[1]: Entering directory `/lib/modules/3.10.27+/build'
make[1]: Leaving directory `/lib/modules/3.10.27+/build'
Maxhdroom
Mon Jan 27, 2014 11:49 pm
Same situation here...
I'm trying to compile a module and can't find the build directory.
I additionally ran sudo aptitude install linux-image-rpi-rpfv linux-headers-rpi-rpfv, still no uname -r/build found, so I ran find / -name build and got
/lib/modules/3.10-3-rpi/build
I altered Makefile accordingly and got a .ko module... so far so good. Then I insmod it and got "Invalid module format" ran dmesg "usbtv: disagrees about version of symbol module_layout" :evil:
uname -a tells me I'm running Linux raspberrypi 3.10.27+ #630 PREEMPT Fri Jan 17 19:44:36 GMT 2014 armv6l GNU/Linux
How do you compile on the Pi ??
Maxhdroom
Tue Jan 28, 2014 1:31 am
I followed these instructions, just adapting to my kernel's version and was able to compile the module, but apparently it crashes my Pi on depmod and insmod.
http://www.raspberrypi.org/phpBB3/viewt ... 76#p315376
cd /usr/src
wget https://github.com/raspberrypi/linux/archive/rpi-3.10.y.tar.gz
tar xvfz rpi-3.10.y.tar.gz
mv linux-rpi-3.10.y linux
ln -s /usr/src/linux /lib/modules/3.10.27+/build
cd /lib/modules/3.10.27+/build
make mrproper
gzip -dc /proc/config.gz > .config
make modules_prepare
wget https://github.com/raspberrypi/firmware/raw/master/extra/Module.symvers
then got in the dir where I downloaded the module source code and ran make.
Copied the resulting .ko to /lib/modules/$(uname -r)/kernel/drivers/
depmod -a ran ok
Then modprobe crashes the system... does linux code have to be specifically adapted for Raspberry Pi ?
Reiszecke
Thu Feb 06, 2014 3:44 am
Same here, any solutions so far?
PiWolli
Mon Mar 03, 2014 8:25 pm
I had the same problem.
There is an easy solution for the Problem:
1. Try to install linux-headers
sudo apt-get install linux-headers
You get a message that you try to install a virtual package and you have to install a concrete package. You find a list of concrete packages.
2. Install the concrete package
sudo apt-get install linux-headers-3.10-3-rpi
3. Now the trick. You have to link the new build folder with the missing folder.
sudo ln -s /lib/modules/3.10-3-rpi/build /lib/modules/3.10.25+/build
That's it. Now I can compile the driver. After install the drivers my WLAN module works fine.
Reiszecke
Tue Mar 25, 2014 4:35 am
THANKS SO MUCH! That did it for me. Now I am running into the next problem, might have sth to do with that >.>
http://www.raspberrypi.org/phpBB3/viewt ... 28&t=73005
nebula
Wed Mar 26, 2014 3:05 am
PiWolli wrote:I had the same problem.
Thank you!! I`ve been searching all over the place for this answer.
Seb0
Mon Apr 28, 2014 8:35 am
Thanks a lot, the make works well.
Will the driver compiled works well too?!
nipponese
Tue May 13, 2014 7:26 am
@PiWolli Thanks for this! So why is the install script looking for the wrong headers dir?
edwin6938
Wed Jun 04, 2014 4:18 pm
It doesn t work for me... i have an error. Unable to fetch some archives. ..
LiudvikasLTU
Thu Jul 24, 2014 8:50 am
BUMP
I have the same problem as above. Anyone know what should I do?
epierre
Sun Nov 22, 2015 5:13 pm
this page well indexed need some updates.
first find your kernel version: uname -a
then search for headers: apt-cache search linux-headers
From it, and since I run a PI2 on a 3.18.5 I have chosen and installed: apt-get install linux-headers-3.18.0-trunk-rpi2
Then I made the symlink: sudo ln -s /lib/modules/3.18.0-trunk-rpi2/build /lib/modules/3.10.25+/build
and then edit Makefile for ARM:
CONFIG_PLATFORM_I386_PC = n
CONFIG_PLATFORM_ARM_RPI = y
and to finish :make / make install which is fine
abm413
Sun Mar 27, 2016 10:50 pm
hey!!! how to get it working for the latest kernel version? help plssss
abm413
Tue Mar 29, 2016 10:48 pm
what is the third step for the newest raspbian jessy? can you tell me please?
Tue Mar 29, 2016 11:00 pm
abm413 wrote:hey!!! how to get it working for the latest kernel version? help plssss
Use https://github.com/notro/rpi-source that does everything you need to get a kernel build environment built (run on your RPi for your current RPi kernel).
leftcoastshot
Re: HELP: Compiling driver error, no /lib/modules/3.10.25+/build
Sun Feb 10, 2019 5:32 am
This issue is still around. The error I received in response to my make command:
/lib/modules/4.9.35+/build: No such file or directory.
I found a solution after lots of browsing ... execute this syntax:
sudo apt-get install raspberrypi-kernel-headers
Now my make command succeeds.
gubertoli
Sun Jul 07, 2019 2:53 pm
Perfect! This approach worked for Raspbian Stretch and Kernel 4.19.50-v7+
bipbip38
Fri Aug 16, 2019 2:03 pm
I have the same trouble.
 sudo mkdir /lib/modules/4.19.58-v7+/build
 sudo apt autoremove
 sudo ln -s /lib/modules/4.19.58-v7+/build
 sudo make
 rm rf *.o *~core .depend .*.cmd *.ko *.mod.c .tmp_versions Module.* modules.order
 make -c /lib/modules/4.19.58-V7+/build M=/home/GobiSerial modules
 make[1]: Entering directory `/lib/modules/4.19.58-v7+/build'
 make: *** [makefile:6: all] Error 2
The makefile is :
obj-m := GobiSerial.o
KDIR := /lib/modules/$(shell uname -r)/build
PWD := $(shell pwd)
all: clean
$(MAKE) -C $(KDIR) M=$(PWD) modules
clean:
rm -rf *.o *~ core .depend .*.cmd *.ko *.mod.c .tmp_versions Module.* modules.order
some body knew how resolve this trouble?
Thx
Return to “Beginners”
