HUB USB 3.0 don't work, how fix?
Posted: Mon Jan 20, 2014 4:31 pm
by szymon1051
I have praspberr pi b and use raspbian.
Hub ORICO A3H10.
Re: HUB USB 3.0 don't work, how fix?
Posted: Mon Jan 20, 2014 11:12 pm
by sdjf
Do you also have a USB 2.0 hub in the house? I have read posts in the forum where people plugged the 2.0 Hubs into their pi and then plugged their 3.0 hubs or devices into the 2.0 hubs and they they worked. At least I think that is what I read. ;o) Would not hurt to try it.
Another thing that might be your problem is if the Hub is drawing too much power from the Pi, is it a powered hub? You really need one if you want to connect much to the Pi over Usb.
Posted: Tue Jan 21, 2014 11:24 am
by szymon1051
sdjf wrote: Another thing that might be your problem is if the Hub is drawing too much power from the Pi, is it a powered hub? You really need one if you want to connect much to the Pi over Usb.
Hub have own power.
sdjf wrote:Do you also have a USB 2.0 hub in the house? I have read posts in the forum where people plugged the 2.0 Hubs into their pi and then plugged their 3.0 hubs or devices into the 2.0 hubs and they they worked. At least I think that is what I read. ;o) Would not hurt to try it.
I try add hub 3.0 (with own power) to hub 2.0 (with own power) and to pi, but still don't work.
Posted: Tue Jan 21, 2014 5:18 pm
by Jessie
Have you tried the hub on a PC to make sure it works?
Posted: Tue Jan 21, 2014 9:17 pm
by szymon1051
Jessie wrote:Have you tried the hub on a PC to make sure it works?
Yes.
Posted: Mon May 05, 2014 1:53 pm
by vallieres
Have you guys managed to make it work? I also have a USB 3.0 hub, the Orico H10-U3 and I can't get it to work with my Raspberry Pi... :(
Posted: Mon May 05, 2014 5:32 pm
by jdb
Posted: Tue May 06, 2014 5:04 pm
by vallieres
Actually, with the dwc_otg.speed=1 change in cmdline.txt it works :)
