HUB USB 3.0 don't work, how fix?
I have praspberr pi b and use raspbian.
Hub ORICO A3H10.
Re: HUB USB 3.0 don't work, how fix?
Do you also have a USB 2.0 hub in the house? I have read posts in the forum where people plugged the 2.0 Hubs into their pi and then plugged their 3.0 hubs or devices into the 2.0 hubs and they they worked. At least I think that is what I read. ;o) Would not hurt to try it.
Another thing that might be your problem is if the Hub is drawing too much power from the Pi, is it a powered hub? You really need one if you want to connect much to the Pi over Usb.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
Hub have own power.sdjf wrote: Another thing that might be your problem is if the Hub is drawing too much power from the Pi, is it a powered hub? You really need one if you want to connect much to the Pi over Usb.
I try add hub 3.0 (with own power) to hub 2.0 (with own power) and to pi, but still don't work.sdjf wrote:Do you also have a USB 2.0 hub in the house? I have read posts in the forum where people plugged the 2.0 Hubs into their pi and then plugged their 3.0 hubs or devices into the 2.0 hubs and they they worked. At least I think that is what I read. ;o) Would not hurt to try it.
Have you tried the hub on a PC to make sure it works?
Yes.Jessie wrote:Have you tried the hub on a PC to make sure it works?
Have you guys managed to make it work? I also have a USB 3.0 hub, the Orico H10-U3 and I can't get it to work with my Raspberry Pi...
Rockets are loud.
https://astro-pi.org
Actually, with the dwc_otg.speed=1 change in cmdline.txt it works
