reggie4
1.7gb on a 4gb card
Wed Jan 15, 2014 2:28 pm
I have a working image on my 4GB card, but wanted to try a different image so:
1) I backed up the old image, using win32discimager
2) Formatted the card using sdformatter v4.0, with format size adjustment "on"
Unfortunately the size box was 1.17 GB and whatever i did, i couldn't change the size to 4GB.
Now when i try and copy, using win32discimager, the new image to the sd card it fails to copy because i haven't enough space on the card!
I seem to remember this happening before, but i cannot remember how to reformat it to 4GB, Please could someone help me reformat to 4GB,
thanks
Reggie.
lazarus78
Re: 1.7gb on a 4gb card
Wed Jan 15, 2014 7:10 pm
Just re-format the SD card with... anything, as Fat32.
FTrevorGowen
Wed Jan 15, 2014 7:26 pm
The SDA's formatting tool should "do the job" - but you need the "FULL (Overwrite) FORMAT" setting as well as "FORMAT SIZE ADJUSMENT ON" (as shown in the screenshots here: http://www.cpmspectrepi.webspace.virgin ... 121XP.html)
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Joe Schmoe
Wed Jan 15, 2014 7:35 pm
Wouldn't it be easier just to do:
dd if=/dev/zero of=/dev/sdb count=1
Then stick the card in your digital camera...?
(The 'dd' command may or may not be necessary, depending on your camera, but it can't hurt...)
Wed Jan 15, 2014 7:41 pm
Filling the card with zeros is a Very Bad Idea®. There's a difference between a byte with zero and a never used byte on an SDCard when it comes to wear levelling.
It's easier to use
fdisk -l /dev/sda # to delete all partitions and create a single type 0x0C primary partition
mkfs.vfat /dev/sda1
Or use the SD Formatter on Windows.
This is a doctor free zone.
reggie4
Thu Jan 16, 2014 7:01 pm
Hi all and thanks for all your suggestions,
I remembered before that I re-formatted it within my camera and it worked; so i tried it again and bingo!
Dougie you say
It's easier to use
mkfs.vfat /dev/sda1
, is this within windows via cmd?
Thanks for your help,
Reggie.
Thu Jan 16, 2014 7:56 pm
I do all my SDCard stuff on either my RPi or my Ubuntu system. Windows isn't smart enough to see the filesystems and read/write/fix/damage them. Windows is very good at ignoring lots of the useful megabytes on a RPi SDCard.
