I am quite new on Linux and I am trying to understand the high memory usage I always get on my freshly installed Debian on the Raspberry pi.
pi@raspberrypi:~$ ps -aux
Warning: bad ps syntax, perhaps a bogus '-'? See http://procps.sf.net/faq.html
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 2076 188 ? Ss 03:02 0:01 init [2]
root 2 0.0 0.0 0 0 ? S 03:02 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S 03:02 0:00 [ksoftirqd/0]
root 5 0.0 0.0 0 0 ? S 03:02 0:01 [kworker/u:0]
root 6 0.1 0.0 0 0 ? S 03:02 0:35 [rcu_kthread]
root 7 0.0 0.0 0 0 ? S< 03:02 0:00 [khelper]
root 8 0.0 0.0 0 0 ? S 03:02 0:00 [kdevtmpfs]
root 9 0.0 0.0 0 0 ? S 03:02 0:00 [sync_supers]
root 10 0.0 0.0 0 0 ? S 03:02 0:00 [bdi-default]
root 11 0.0 0.0 0 0 ? S< 03:02 0:00 [kblockd]
root 12 0.0 0.0 0 0 ? S 03:02 0:00 [khubd]
root 13 0.0 0.0 0 0 ? S< 03:02 0:00 [rpciod]
root 14 0.0 0.0 0 0 ? S 03:02 0:07 [kswapd0]
root 16 0.0 0.0 0 0 ? S 03:02 0:00 [fsnotify_mark]
root 17 0.0 0.0 0 0 ? S< 03:02 0:00 [nfsiod]
root 18 0.0 0.0 0 0 ? S< 03:02 0:00 [crypto]
root 25 0.0 0.0 0 0 ? S< 03:02 0:00 [VCHIQ-0]
root 26 0.0 0.0 0 0 ? S< 03:02 0:00 [VCHIQr-0]
root 27 0.0 0.0 0 0 ? S< 03:02 0:00 [dwc_otg]
root 28 0.0 0.0 0 0 ? S< 03:02 0:00 [DWC Notificatio]
root 29 0.0 0.0 0 0 ? S 03:02 0:00 [kworker/u:1]
root 30 3.9 0.0 0 0 ? D 03:02 14:32 [mmcqd/0]
root 31 0.0 0.0 0 0 ? S 03:02 0:03 [jbd2/mmcblk0p2-]
root 32 0.0 0.0 0 0 ? S< 03:02 0:00 [ext4-dio-unwrit]
root 73 0.0 0.1 2480 392 ? S<s 03:02 0:00 udevd --daemon
root 660 0.0 0.0 1712 160 ? S 03:03 0:11 /usr/sbin/ifplugd -i eth0 -q -f -u0 -d10 -w -I
daemon 661 0.0 0.0 1828 120 ? Ss 03:03 0:00 /sbin/portmap
statd 676 0.0 0.0 2040 132 ? Ss 03:03 0:00 /sbin/rpc.statd
root 677 0.0 0.0 1712 164 ? S 03:03 0:03 /usr/sbin/ifplugd -i lo -q -f -u0 -d10 -w -I
root 860 0.0 0.3 27544 828 ? Sl 03:03 0:02 /usr/sbin/rsyslogd -c4
102 910 0.0 0.2 2836 552 ? Ss 03:03 0:00 /usr/bin/dbus-daemon --system
root 928 0.0 0.1 3968 248 ? Ss 03:03 0:00 /usr/sbin/cron
root 936 0.0 0.0 2308 100 ? Ss 03:03 0:00 dhclient -v -pf /var/run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases eth0
116 947 0.0 0.5 15184 1316 ? Ssl 03:03 0:00 /usr/sbin/hald
root 948 0.0 0.3 3720 676 ? S 03:03 0:00 hald-runner
ntpd 959 0.0 0.3 5432 720 ? Ss 03:03 0:04 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 119:127
root 997 0.0 0.1 5884 384 ? Ss 03:03 0:00 /usr/sbin/sshd
root 1024 0.0 0.0 3736 148 tty1 Ss 03:03 0:00 /bin/login --
root 1025 0.0 0.1 1704 232 ? Ss+ 03:03 0:00 /sbin/getty -L ttyAMA0 115200 vt100
root 1026 0.0 0.0 3736 148 tty3 Ss 03:03 0:00 /bin/login --
root 1027 0.0 0.0 1704 120 tty4 Ss+ 03:03 0:00 /sbin/getty 115200 tty4
root 1028 0.0 0.0 1704 120 tty5 Ss+ 03:03 0:00 /sbin/getty 115200 tty5
root 1029 0.0 0.0 1704 120 tty6 Ss+ 03:03 0:00 /sbin/getty 115200 tty6
root 1031 0.0 0.7 17612 1692 ? Sl 03:03 0:00 /usr/sbin/console-kit-daemon --no-daemon
pi 1103 0.0 0.3 4708 848 tty1 S 03:03 0:01 -bash
root 1150 0.0 0.0 0 0 ? D 03:56 0:10 [flush-179:0]
root 2780 0.0 0.2 2476 496 ? S< 04:29 0:00 udevd --daemon
root 2782 0.0 0.2 2476 504 ? S< 04:29 0:00 udevd --daemon
root 2797 0.0 0.5 3820 1120 ? S 04:29 0:00 hald-addon-input: Listening on /dev/input/event0 /dev/input/event1
pi 3066 0.0 0.6 3956 1408 tty1 S+ 04:35 0:00 make
root 17223 0.0 0.0 0 0 ? S 07:44 0:03 [kworker/0:2]
root 22652 0.0 0.0 0 0 ? S 09:07 0:00 [kworker/0:1]
pi 22938 0.0 0.4 3588 996 tty1 S+ 09:09 0:00 make -f scripts/Makefile.build obj=sound
pi 23028 0.0 0.4 3588 1012 tty1 S+ 09:10 0:00 make -f scripts/Makefile.build obj=sound/core
pi 23136 0.2 0.4 3588 1048 tty1 S+ 09:11 0:00 make -f scripts/Makefile.build obj=sound/core/seq
root 23283 0.0 0.0 0 0 ? S 09:13 0:00 [kworker/0:0]
pi 23343 0.2 0.4 3588 1024 tty1 S+ 09:13 0:00 make -f scripts/Makefile.build obj=sound/core/seq/oss
root 23400 2.6 1.3 9480 2952 ? Ss 09:14 0:00 sshd: pi [priv]
pi 23427 0.4 0.6 9480 1512 ? S 09:14 0:00 sshd: pi@pts/0
pi 23428 0.4 0.8 4692 1792 pts/0 Ss 09:14 0:00 -bash
pi 23450 0.3 0.2 1728 512 tty1 S+ 09:14 0:00 /bin/sh -c set -e; ? echo ' CC [M] sound/core/seq/oss/seq_oss_writeq.o'; gcc -Wp,-MD,sound/co
pi 23451 0.3 0.3 3336 764 tty1 S+ 09:14 0:00 gcc -Wp,-MD,sound/core/seq/oss/.seq_oss_writeq.o.d -nostdinc -isystem /usr/lib/gcc/arm-linux-gnue
pi 23452 109 5.9 22252 13396 tty1 R+ 09:14 0:03 /usr/lib/gcc/arm-linux-gnueabi/4.4.5/cc1 -quiet -nostdinc -I/home/pi/kernel/linux/arch/arm/includ
pi 23453 0.0 0.4 4068 1012 pts/0 R+ 09:14 0:00 ps -aux
pi@raspberrypi:~$ free -m
total used free shared buffers cached
Mem: 218 200 18 0 18 148
-/+ buffers/cache: 33 185
Swap: 190 4 186
ps does not shown any heavy process.
How can I find the processes using a large amount of memory ?
Thank you.
