plocplic
First time Can't boot my RP
Thu Jan 09, 2014 9:43 am
Hello everybody
I shall assume my lake of knowledge and ability (also my rude english : i'm french !)
I received a Raspberry pi from The Pi-Hut
I followed some tutoriels to my first boot but nothing happened : no video signal (the RP is plugged to a video screen with a video connection)
I read that maybe the SD card has not been properly fullfilled, I formatted it and downloaded NOOBS and followed the instructions, but still my RP refuses to boot...
I'm very sad... Does anybody have any idea ?
Any help would be very appreciated and remember to explain everything as if I were a 5 years old boy
pmac
Re: First time Can't boot my RP
Thu Jan 09, 2014 10:39 am
Hi, did you use the format tool at https://www.sdcard.org/downloads/formatter_4/?
Also the instructions http://elinux.org/RPi_Easy_SD_Card_Setup may help.
I went through this quite a few times before figuring out my SD card didn't work very well with the Pi. Another card solved my problems.
EDIT: trouble shooting boot problems: http://elinux.org/R-Pi_Troubleshooting# ... F_Start-up
Do have a good look through the R Pi hub at the elinux site. Much helpful advice there. :D
2nd edit: also see sticky post in this forum: http://www.raspberrypi.org/phpBB3/viewt ... 91&t=58743
sdjf
Thu Jan 09, 2014 3:26 pm
The first thing to do is make sure you have an adequate power supply. What are you using to power your Pi?
Do any of the lights on the Pi flash when you plug it in? Which ones? Are there any patterns?
Have you looked at the following page?
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
plocplic
Thu Jan 09, 2014 4:27 pm
Thanks for your answers
I wasn't able to check the voltage measure of my power supply but the power supply comes from The Pi Hut so it should be dedicated to the Rpi
I did have the red light, the green one (which flashed a little moment) and two orange ones...
The SD card also was from The Pi Hut, I formatted it because it was not working I followed the official instructions as carefully as I can...
I'll try again tonight
plocplic
Thu Jan 09, 2014 7:47 pm
So I just tried again
The red light is constantly on
The green flashed 3 or 4 times at the beginning but no more after.
I still don't have any video signal.
I've checked the SD card sent by The Pi Hut it's a Kingston 8Go / SD4
If I follow the link http://elinux.org/RPi_SD_cards
it's not so clear because there's two similar cards :
ok Kingston SDHC 8 4 SD4/8GB Works reliably with Raspbian 18-9-2012 and previous Debian releases (Picards) Md84419 5 Nov 2011, Picards 28 Oct 2012
nok Kingston SDHC 8 4 SD4/8GB does not work with current build of raspbmc (LastSilmaril), unreliable with raspbian (Quentinsf) LastSilmaril 24 May 2012, Quentinsf 20 Oct 2012
Maybe that's the problem, I don't know... The Pi Hut is serious, no ?
Please help me, it was my very first day with my Rpi !
Thu Jan 09, 2014 7:56 pm
Try editing /boot/config.txt (F:\config.txt on windows)
Add
boot_delay=1
save the file and try it again in your RPi.
plocplic
Thu Jan 09, 2014 8:03 pm
Dougie, thanks for your help
But I'm not sure to understand what I have to do, sorry my knowledge are very poor
My computer is a mac
If you can be little more precise, it would be very helpful
For the moment, I formatted again the card and I'm downloading the very late version of Noobs
plocplic
Thu Jan 09, 2014 9:47 pm
Ok time to get some rest...
Still no success
1/ I've formatted the card and downloaded the late version of NOOBS
2/ I've tried to follow the config.tx suggested by Dougie but maybe I've done wrong or have not understood what to do exactlyhttp://elinux.org/R-Pi_ConfigurationFile
3/ I've tried another SD Card I have (Sandisk 8gb/10/Ultra)
4/ I've tried another screen with RCA connection
I'm gonna drink a bootle of wine and tomorrow is another day...
FTrevorGowen
Thu Jan 09, 2014 10:22 pm
plocplic wrote:Ok time to get some rest...
Still no success
NOOBS has just been updated to (hopefully) fix the "boot delay" issue (see the end of this long thread: http://www.raspberrypi.org/phpBB3/viewt ... 28&t=64330) . I don't think Kingston cards are a problem (any more - the elinux wiki info. is now quite old) - I use quite a few: http://www.cpmspectrepi.webspace.virgin ... cards.html . Using NOOBS with composite video is "tricky" as noted in my "screenshot-based guides" to the NOOBS installation process at: http://www.cpmspectrepi.webspace.virgin ... ellow.html (there is a "backlink" to HDMI-based installation there too).
Given that you have been seeing "green LED ACTivity", that suggests that the boot process is starting but, may be, not leading to a suitable video output for your display types.
Trev.
plocplic
Fri Jan 10, 2014 7:56 am
I'll try with a HDMI/VGA connection and my usual screen
FTrevorGowen
Fri Jan 10, 2014 9:18 am
plocplic wrote:Thanks for your answer
You're welcome. FWIW, some notes on my trials of a HDMI to VGA adapter are here: http://www.cpmspectrepi.webspace.virgin ... erter.html
(there's a link to a few NOOBS 1.3.3 snapshots using it in the footnotes)
Trev.
plocplic
Fri Jan 10, 2014 2:44 pm
Hello everybody
I went out to buy a HDMI_DVI cable et now it starts
So my video connection was the problem. Do you think i can solve that problem because I would prefer using a small 7" screen rather than my computer's
Thanks anyway for your answers
Kinds regards
FTrevorGowen
Fri Jan 10, 2014 4:11 pm
plocplic wrote:Hello everybody
Kinds regards
It's probably worth starting a new thread with some details of your 'small 7" screen' and ask for help/guidance therein.
Trev.
sdjf
Fri Jan 10, 2014 4:28 pm
If you are attaching a portable 7" screen I would guess that is a USB monitor and you will need to attach it to the Pi with a powered hub. Otherwise, it will take too much power and not work. Unless it is a composite monitor, but the Pi only has so many devices it can power and it might be worth investing in a device that measures the power so you can debug problems better. In the USA they are called multimeters.
