Gailhill66
Help VGA to HDMI converters
Fri Jan 03, 2014 6:03 pm
Hi everyone
and my apologies since my query is undoubtedly a repetition but I can't find out what to do.
After a long day setting everything up and a trip to Maplins to get a VGA to HDMI converter (which cost a painful £49.99!) my son and I triumphantly plugged everything in, only for my monitor to refuse to come on! Thinking perhaps my monitor had died whilst inactive, I then plugged it back into my cranky old pc and it works fine.
So I reconnected it to the converter, plugged everything into the Raspberry pi and not a dicky bird. The Raspbery Pi seems to be working (all the lights were on and I did download NOOBs as per instructions), ethernet cable showing good signs of life attached to my router, but nothing on the monitor! The converter has a blue light shining on the VGA side but nothing on the HDMI side. I am at a loss what to do next, as I read carefully and was convinced this would work.
If anyone is kind enough to reply, I am a complete beginner, so please explain any technical terms.
Thanks very much.
mahjongg
Re: Help VGA to HDMI converters
Fri Jan 03, 2014 8:13 pm
Probably your converter prevents reading the monitors EEPROM with monitor setting, so you must set the configuration manually, see the wiki at http://elinux.org/RaspberryPiBoard and search for config.txt.
Fri Jan 03, 2014 9:54 pm
Gailhill66 wrote:After a long day setting everything up and a trip to Maplins to get a VGA to HDMI converter
Shouldn't that be a HDMI to VGA converter? It needs to convert the HDMI output of the Pi to the VGA input of your monitor.
rudiel
Fri Jan 03, 2014 10:14 pm
You can us a simple HDMI to DVI adapter if your monitor has a DVI input. Also have a look at www.seeedstudio.com they have a nice looking HDMI to VGA adapter going for US $9.90.
hope this helps..
Rudie
mahjongg
Fri Jan 03, 2014 10:26 pm
HDMI and DVI use exactly the same signaling, so no electronic conversion is needed, just a different cable.
