Ollifi
Iceweasel and other
Thu Jan 02, 2014 11:23 am
Few questions:
1. How to change Iceweasel start page via SSH?
2. How to change clock/timezone via SSH?
3. What is the best way to clone SD cards with Mac? I am going to have several rasps for the same purpose, info screens.
Thanks for answers.
tvjon
Re: Iceweasel and other
Thu Jan 02, 2014 7:14 pm
For 1 & 2 operations,
http://www.raspberrypi.org/phpBB3/viewt ... 1d64424295
works well IME, as it's almost realtime speed, unlike VNC. This way you operate your RPi just like you would via an attached monitor, keyboard, & mouse.
I would also use this method for 3, as cloning a SD card on RPi works fine & is no slower than an external computer.
However, if you want to do it directly on your mac, open Terminal,
tvj$ diskutil unmountDisk whatever-your-SD-is-in-Finder
tvj$ dd bs=1m of=/dev/whatever-your-SD-is-in-Finder if=/Users/tvj/yourdiskImage
HTH
Ollifi
Fri Jan 03, 2014 10:09 am
1.2. ~ That utility didn't work. Just normal SSH opened. So can you give me direct advice how to do those in command line,without graphic UI?
3.~ Thanks for advice, is there any graphic utility for Mac? Like for Windows.
klricks
Fri Jan 03, 2014 1:16 pm
For timezone run:
sudo raspi-config
Ollifi
Sat Jan 04, 2014 1:51 pm
Thank you. What about the front page thing?
ghans
Sat Jan 04, 2014 2:52 pm
Do you have the X Server installed ? Apple does not include
it by default , but it should still be included on the installation
disk.
ghans
Ollifi
Mon Jan 06, 2014 7:26 am
This is mid-2013 MBA. So I don't have any disks for it. Is there a place where I could download it? Though, it would be easier to do everything in the command line.
ghans
Mon Jan 06, 2014 7:33 am
tvjon
Mon Jan 06, 2014 12:09 pm
Ollifi wrote:Hi,
1.2. ~ That utility didn't work. ..
I don't understand what you mean by "utility".
utility? To do what?
The couple of mac's I've used for this exercise both worked straight from Terminal (or iTerm for example) - no additional software required on RPi or macintosh.
As is often the case with posters, you've not provided any information about what you've actually tried, or system software & hardware.
So, it occurs to me you may be using Mountain Lion or Mavericks? I only currently have access to older machines, so Snow Leopard & Lion.
Take a look at this thread:
http://www.raspberrypi.org/phpBB3/viewt ... 44#p245144
where you'll find useful information from experienced Linux contributors, including ghans.
HTH
Ollifi
Mon Jan 06, 2014 5:10 pm
About the SD backup;
There comes two different, boot and RECOVERY, when inserting my SD card. Which should I backup?
And is it possible to use this instructions to make a backup: https://wikis.utexas.edu/display/comm/M ... ur+SD+Card
With utility I mean app. Some app with graphical interface to do the backup. (Disk Utility?)
