fishxz
ir gpio need help
Mon Dec 30, 2013 10:54 pm
hey,
i want to connect my old serial ir receiver to my rpi, now im asking me if this possible, if yes how i need to connect it? i have no datasheet.
here is a screenshot of the cable:
https://www.dropbox.com/s/ctemh6y3b31mm ... 234917.jpg
joan
Re: ir gpio need help
Mon Dec 30, 2013 10:59 pm
If that was used on a PC it probably operates at +/- 12V and would be incompatible with the Pi's 3.3V logic levels.
You could probably use the IR receiver itself if it was de-soldered. Do you know the IR receiver model?
You may be able to connect it directly to a gpio.
fishxz
Mon Dec 30, 2013 11:03 pm
i only want to use the ir receiver, but i dont know the model of the receiver :(
joan
Mon Dec 30, 2013 11:08 pm
fishxz wrote:i only want to use the ir receiver, but i dont know the model of the receiver :(
I meant the IR chip itself. I sort of made the assumption that you built that yourself as per http://www.lirc.org/receivers.html and http://www.lirc.org/pictures1.html
fishxz
Mon Dec 30, 2013 11:16 pm
oh... no. i didnt built it myself.
fishxz
Mon Dec 30, 2013 11:33 pm
its looks for me like an TSOP1737???
exartemarte
Tue Dec 31, 2013 12:40 am
If it was used with a PC serial port you could try a USB/serial converter like this. They are very cheap on eBay. I have a couple of them, and although I haven't tried them on a Pi I have used them successfully with Debian Linux on PC and laptops - didn't even have to install a driver.
Return to “Beginners”
