dddddddd207
I screwed up my networking and can't figure out how I did it
Fri Dec 27, 2013 8:33 pm
Well, I got a Pi for Christmas and installed Rasbian on it, and decided to give it a static IP address. I'm new to linux, so I followed some instructions online and added the lines about "address 192.168.168.150" and etcetera and restarted the networking service, but when I tried to ping anything, it just said "connect: Network is unreachable." I hadn't backed up the original interfaces file, so I reinstalled the OS, backed up the interfaces file, and tried again. It still didn't work, and so I restored the original interfaces file and restarted the networking service, and it still doesn't work.
So I screwed something up, but I can't figure out what I screw up, or how I screwed it up. Can you help?
sdjf
Re: I screwed up my networking and can't figure out how I di
Fri Dec 27, 2013 10:31 pm
What hardware is attached to your Pi? Answers depend on the setup. If too many devices are attached to the Pi that require more power than it can deliver, they will not work.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
jozzan
Fri Dec 27, 2013 10:39 pm
Could you please give some info on your network?
prefix - such as: 192.168.2.x
netmask
router-ip
as well as the output of this command:
ifconfig
this command by the prints network configuration for all network devices.
Fri Dec 27, 2013 10:44 pm
On windows open a command window and get the output from an ipconfig /all command.
That will give you the strange incantations to use for your RPi
Here's a redacted example from my Win8.1 system
C:\Users\Dougie>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Dougies-Lenovo
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : domain_not_set.invalid
Ethernet adapter Ethernet 2:
   Connection-specific DNS Suffix  . : domain_not_set.invalid
   Description . . . . . . . . . . . : Microsoft Network Adapter Multiplexor Dri
ver #2
   Physical Address. . . . . . . . . : 00-FF-F7-4E-C9-7F
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv6 Address. . . . . . . . . . . : 2001:xxx:xxxx:xxx:144b:9f33:a8be:be7c(Pre
ferred)
   Temporary IPv6 Address. . . . . . : 2001:xxx:xxxx:xxx:bcb7:3ed6:d2c0:f8e7(Pre
ferred)
   Link-local IPv6 Address . . . . . : fe80::144b:9f33:a8be:be7c%17(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.58(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 27 December 2013 08:57:58
   Lease Expires . . . . . . . . . . : 28 December 2013 08:57:59
   Default Gateway . . . . . . . . . : fe80::214:bff:fe23:5c9%17
                                       192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 436273143
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-6D-7C-9A-08-3E-8E-AB-DE-93
   DNS Servers . . . . . . . . . . . : 192.168.1.1
                                       8.8.8.8
                                       8.8.4.4
   Primary WINS Server . . . . . . . : 192.168.1.4
   NetBIOS over Tcpip. . . . . . . . : Enabled
The exciting parts of that are IPv4 address, Default (IPv4) gateway, Subnet mask & DNS servers.
Richard-TX
Fri Dec 27, 2013 11:04 pm
I recommend a ifconfig -a to see all of the interfaces.
Then a netstat -rn to see the routing table.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
dddddddd207
Fri Dec 27, 2013 11:07 pm
And fixed it!
Just needed to reboot.
