michaelkrtikos
XRDP and SAMBA via Internet
Sat Dec 21, 2013 11:51 pm
Hello everyone,
I have finally set up my RPi exactly the way i wanted. I have a dual boot system with Raspbian and OpenELEC. On Raspbian i have set up xrdp (with static IP address) for remote access and Samba for NAS capabilities. The OpenELEC is more or less standard i have just installed the desired add-ons. I have also created an image of my SD card and saved it on my computer as a clean install with the packages i need.
The way it is now, i can access it either via xrdp or via the mapped network drive i have created on my computer. I also use PocketCloud (for remote access) and FileExplorer (access to the NAS) from my iOS devices. I can only access it on my local network though.
I would like to be able to access both of the above services via Internet. For example, when i am shooting a picture with my phone i can later on upload it to my drive from anywhere. Also when i want to change a setting i would like to be able to remote access my system via RDP.
I have forwarded some ports on my router but it doesn't seem to work. Since i am a new user to all these, could you please instruct me with simple steps what settings i need to set (either on router or on the OS) in order to be able to achieve the desired results?
Thank you very much in advance!
http://www.theraspberrypiblog.com
remsnet
Contact: Website Yahoo Messenger
Re: XRDP and SAMBA via Internet
Sun Dec 22, 2013 12:45 am
michaelkrtikos wrote:Hello everyone,
NO way to get an menu boot up on PI Today.
buy aother PI - they are cheap.
michaelkrtikos
Sun Dec 22, 2013 1:00 am
I am not looking for a way to have a multiboot Pi, i already have this with BerryBoot.
All i want is to be able to access it via internet!
GoodGuy98
Sun Dec 22, 2013 1:55 am
This google search may offer some suggestions
https://www.google.com/#q=access+raspbe ... t&start=10
It might be helpful to look into BarracudaDrive for Raspberry Pi
http://barracudadrive.com/
http://barracudadrive.com/RaspberryPi.lsp
michaelkrtikos
Sun Dec 22, 2013 11:56 am
I don't know how to thank you, you are a GoodGuy :)
BarracudaDrive did the trick... Easy to set set up and straightforword!
Thank you very much! With your help I have now completed the Raspberry Pi set up!
Return to “Beginners”
