I am an absolute beginner - or not even that. I have just placed my order. I would like some advice on what extra hardware I should buy.
My main use of RPi would be to run XBMC. I need to connect to S/PDIF in on my receiver. I plan to control it via the XBMC remote on my Android phone. I also plan to install FreeNAS on an old computer to use as a network storage. If this works, I would have a potentially totally quiet media center.
What I have is: a VGA monitor, and a projector with VGA, composite or s-video in. I have a composite or s-video to vga converter - this doesn't give a high quality picture, but it is sufficient for basic work. I probably have a working SD-card. And I can borrow keyboard and mouse. So what I need is S/PDIF out, plus decide on how I should connect to my monitor.
I can see two ways to have the S/PDIF out and vga connection:
1) Use the composite out and my composite to vga converter, plus an USB soundcard with S/PDIF out.
2) Use the HDMI out, and a HDMI to vga and S/PDIF converter. There are boxes that converts to vga + S/PDIF (http://www.dealextreme.com/p/hdv-338-hd ... 824?item=6) or http://www.ebay.co.uk/itm/2-HDMI-VGA-YP ... 2c6402dd46. Alternatively, I could use a HDMI splitter, plus separate converters for HDMI to vga and HDMI to S/PDIF.
The last option is quite pricey, but I suspect that it would be better for the video signal. What would you advice me to do?
Then I have a some other questions:
Can RPi connect to a network disk set up by FreeNAS?
Can I control RPi from a PC via remote desktop?
Do I need to have all components (monitor, keyboard, mouse) connected for the RPi to work? If I control it via the phone remote or remote desktop I don't really need it.
