Tipj98
What does your raspberry pie come with?
Mon May 21, 2012 6:09 pm
My raspberry pie is ment to be coming soon so I am thing about the staff I need. My main question is does it come with a memory card. If it does not where can u get the cards that all ready have the raspberry pie software on them.
Thank you
spurious
Re: What does your raspberry pie come with?
Mon May 21, 2012 6:49 pm
memory is built in.. click the FAQ for more details
stevepdp
Mon May 21, 2012 6:52 pm
Moved to Basic Setup and Usage
Hi Tipj98.
The Raspberry Pi normally doesn't come with peripherals. You'll receive a static wrapped board in a box with some instructions. So you'll need to look up buying a compatible SD card and a good regulated micro-usb power supply rated at least 5v 700mA. You'll also want to locate low-power peripherals such as a keyboard and mouse.
The keyboard I picked up recently for it draws just 20mA and is an A4Tech model KL-5 USB keyboard. Highly recommended :-)
My understanding is that preloaded SD cards are not yet available, but will be when the official Raspberry Pi shop launches. We haven't got a date for that yet ;-)
Fortunately, writing an SD card is incredibly easy. Simply have a read through this document at the wiki and you'll soon find the tools necessary for whatever operating system you currently have access to.
Hope this helps you.
Tipj98
Mon May 21, 2012 7:00 pm
Thank u very much
