Hi Everyone,
The RTL8188CUS automatic installation script has been updated. I have made several changes to the script as follows.
1. The script can now configure the driver for unsecured, WEP or WPA/WPA2 networks. The script will now ask whether the network being connected to is unsecured, or uses WEP or WPA/WPA2 security and configures the driver accordingly. In line with this feature if the network selected is unsecured then it will not ask for a password.
2. When inputting the SSID, and PASSWORD if configuring for a secure network, it will ask you to confirm they are correct before installing. If you have typed in either one incorrectly you will have the opportunity to correct it before it is used in the installation.
3. The hotplug feature has now been made optional. You will be asked whether you want it installed or not.
4. The DHCP update has now been made optional. You will be asked whether you want it installed or not.
5. The script has been altered to ensure only the /etc/apt/sources.list file for the Debian6-19-04-2012 release is changed to correct an issue with duplication of package sources, and the sources.list file in any other image will remain unaltered, just in case someone tries to use the script with any other image rather than Debian6-19-04-2012.
6. I have changed the naming convention for the script updates and driver updates which should make life a little easier when an update occurs. The latest script will now be named "install-rtl8188cus-latest.sh" and the latest tarred driver file will be named "8192cu-latest.tar.gz".
Now, rather than hunting out the correct script and driver which have a date code in the name to use to apply the latest update, you will only need to download the script "install-rtl8188cus-latest.sh" and/or the latest driver "8192cu-latest.tar.gz" if you need to manually upgrade the driver. If there has been a change it will be incorporated into these files atomatically. Pointers to these files are in the wiki
on this page.. Look at the links associated with the "Micronet SP907NS, 11N Wireless LAN USB Adapter" wifi adapter.
Before using the script please download and read the installation instructions. Apart from giving details of how to apply the installation the instructions contain important information regarding images that the drivers can be installed on and also contains pointers to some alternative scripts for images other than the Debian6-19-04-2012 image that the script was originally designed to work with.
Have fun and enjoy your Pi.
MrEngman
