Mon Nov 25, 2013 9:18 am
Lamer wrote:Hello, I am very new to Raspberry Pi and I have bought myself a Sandisk Ultra 8GB 30MB/S SD-card (SDSDU-008G) to use on it. I have installed RaspBMC on the card, but it will not boot. Does anyone know of other distros that will work or do I have to return it to the shop. I already have a Sandisk 4GB with RaspBMC which works fine, but I think it's a little slow at some times and I thought that a bigger and faster SD-card would improve the performance.
There has been a booting problem with SanDisk Ultra cards which came to light during early testing of NOOBS 1.3.x . This was solved and fixed in NOOBS 1.3.2 It's possible that this is now "re-appearing" with Raspbmc *img's. I suggest you re-format the card with the SDA Formatter using FULL(Overwrite) and FORMAT SIZE ADJUSTMENT ON modes and then download and unzip NOOBS 1.3.2 onto the card (possibly using an external USB card reader/writer if your computer is more than ~ 3 years old). NOOBS can then be used to install a version of Raspbmc which should boot O.K.
(Download NOOBS from here:
http://www.raspberrypi.org/downloads)
Trev.
