glenngrass
Live Video Stream using Raspberry Pi
Fri Nov 22, 2013 6:35 pm
I have a raspberry pi with a working internet connection(3g mobile broadband- Huawei-E220 using wvdial) and a USB web cam. What I want to do is to make a live webcam video stream available over the Internet.
I'm flexible to use any service like google hangouts/ Skype or any other method based on ffmpeg/motion.
My questions are:
1. Is this task possible using the R-Pi and my USB internet stick?
2. If so, what is the quickest/easiest method I should go through, so that I can do this demonstration ASAP.
(Note:: I will be fixing this unit on a UAV so I don't have the luxury of using a router for port forwarding etc..)
Thank you very much
glenngrass
Re: Live Video Stream using Raspberry Pi
Sat Nov 23, 2013 2:38 pm
Here is what I did. I managed to get a (very weak) video broadcast on Justin.tv
I plugged a web cam(generic/chinese) to one USB port and the Huawei E220 to the other.
Then I follow the steps described in this tutorial. http://techzany.com/2013/09/live-stream ... pberry-pi/
Following the Tutorial worked for me, at least theoritically.
The video uplink is very weak. I guess this is because I'm not using external power to dongle and webcam.
Cheers.
TechZany
Sun Jan 26, 2014 6:33 pm
Hey glenngrass,
Thanks for the referral :) Hope everything is working for you! Cheers!
