I got myself a Pi mainly to play around with and learn some coding / Linux environment experience and so far all is going good.
I'm running the Squeeze build on a 2gb SD card , with the Pi powered from a 3500mah battery pack and using a logitech k400 for input.
I could not get the video to work correctly though, when i try to play something in VLC from a USB pen the first frame will load, then stop but continue toplay the audio flawlessly.
At first I thought the file may be the wrong format so i tried an AVI instead of an MP4, same issue.
Next i updated with
$ sudo apt-get updateI then realised the config file was on the original Start.elf file, so i replaced it with the 128-arm-start.elf file to give the GPU a bit more clout. Same problem.
The only video I can successfully get it to play is a single video ripped from youtube, which is AVI in webcam quality, running but the colours are flawed. the video is a direct rip of this video http://www.youtube.com/watch?v=i1q_rRicAwI with the flames appearing Blue rather than yellow.
I'm running the videos out through HDMI, using VLC.
Have i done something wrong? the only major things (well major to me) i have change is the Auto Login script, the Auto Startx script and I also added the
sudo modprobe snd_bcm2835The Pi now seems to also run choppy since I've changed the video memory settings.
Do any of you nice people have some advice for a Newbie like me
