Hi
a few weeks ago on Liams tuts he advised to use the Fedora remix and showed how to put it on the SD card with Fedora installer , which worked a treat.
Later it was said the new Debian release was better as the Fedora was buggy
I downloaded the Debian release to my pc but then used the the Fedora installer to instal it and
it " appears " to have installed fine . I then used Gparted to increase the partition to use the full 8Gb of the SD card . Everything seemed to go as it should and no errors popped up
I ended up with 11 files on the SD visible in windows which I think I should have
I am still waiting for my Ras Pi to arrive so cant test it yet but my question is
Is it ok to use the Fedora installer to install a Debian release or when I try my sd card in the Pi will it fail miserably ?
Don
