Changing terminal colors
Posted: Tue Nov 12, 2013 11:35 pm
by lazarus78
How can I change the actual color values of terminal colors from the prompt? IE change the shade of red or blue used. The defaults are too bright or dark.
Re: Changing terminal colors
Posted: Wed Nov 13, 2013 3:25 am
by elatllat
LS_COLORS is likely what you arelooking for.
http://www.geekgumbo.com/2011/11/04/cha ... ash-shell/
Posted: Wed Nov 13, 2013 9:45 am
by lazarus78
No, not even close. Ive found tons and tons of such sites with that info, but its not what I am looking for.
I want to change what color "red" is, or change what shade of blue is used when i type in "\e[34m". NOT the color codes used for the LS command.
Example. Debian uses these colors:
https://scottlinux.com/wp-content/galle ... prompt.png
Raspberry uses these:
http://debianhelp.files.wordpress.com/2 ... 4o-jpg.png
I want to change the colors of the raspberry console colors to be like Debian, but I want to do it through the prompt, not the gui terminal "profile" stuff.
Posted: Wed Nov 13, 2013 11:26 am
by JustThisGuy
Check out the command setvtrgb.
Posted: Wed Nov 13, 2013 6:33 pm
by lazarus78
Could use a bit more explanation. Google only yields the basic man page which is borderline unhelpful. The only useful bit is "cat /sys/module/vt/parameters/default_{red,grn,blu} > FILE", but it doesn't tell you what to do with this information. I understand it populates a file with RGB value data, but what do those mean? What is it for? What is it doing and how do I manipulate it for my purposes?
Posted: Wed Nov 13, 2013 8:04 pm
by JustThisGuy
The man page on raspbian is slightly more helpful, showing a table mapping the escape codes to default colors.
The kernel keeps a table of colors used by the virtual terminal. There are 15 to choose from and they correspond to the 'white, black, red, ...cyan' etc colors that can be displayed. Each of these numbers can be set to any RGB specification.
To see what the default spec is you do that 'cat' command into FILE. This file has 3 lines each line contains 15 numbers. The first number in each line contains the red, green,or blue component value respectively for the first displayable color. The second number in each line is value for the second displayable color and so on. (I'm away from my RPi so I'm doing this from memory) For example, the 2nd color is LIGHT RED or 170,0,0. To change this to display blue the numbers change to 0,0,170.
Default color 'map' FILE would contain
0,170,0,170,0,170,0,170,85,255,85,255,85,255,85,255
0,0,170,85,0,0,170,170,85,85,255,255,85,85,255,255
0,0,0,0,170,170,170,170,85,85,85,85,255,255,255,255
edit it to become:
0,0,0,170,0,170,0,170,85,255,85,255,85,255,85,255
0,170,0,0,170,170,170,170,85,85,85,85,255,255,255,255
then execute the command
setvtrgb FILE
which will set the kernel color map to the new definition of RED which will display as the color BLUE. Note that the escape codes (31;01) will still be the same but this should give you control of the 15 possible colors on the console.
Posted: Wed Nov 13, 2013 11:41 pm
by lazarus78
That is far more help then the man page was offering. Thank you.
Another thing. Is this a permanent change? Can I edit the files directly to make it permanent?
Posted: Thu Nov 14, 2013 12:27 am
by JustThisGuy
Actually, I gleaned most of that from the raspbian man page.
As for the persistence I'm not sure. You may have to put a setvtrgb command in your .bashrc or .profile, or probably more correctly in with the sysint stuff in rc.d. But definitely try rebooting it without doing that first and see what happens.
You're welcome.
Posted: Thu Nov 14, 2013 6:31 pm
by lazarus78
Then you are far better at pulling information out of those man pages then I, cus i never would have gotten any of that from little there was.
Thanks for your help.
Posted: Wed Sep 09, 2015 5:20 pm
by petEEy
Can setvtrgb be used with LXTerminals in the desktop environemnt? I can successfully set the colors in the TTY login shells, but when I use setvtrgb on a terminal open in the graphical desktop environment, I get the error "Couldn't get a file descriptor referring to the console". Using "sudo setvtrgb FILE" does not produce this error, but it also doesn't change any of the colors.
