Upload through http?
Posted: Mon Nov 04, 2013 10:15 pm
by HeroS_NL
Hello all,
The raspberry pi is on my list for a long time, so I probably will buy one next week. My plans are to use them as a security camera. I watched alot of youtube video's on this, it suggested to use motion. My idea is (because I cannot access ports therefore can't see it 'real time') to upload video's through http without opening specific ports on my router. Is this possible?
Cheers!
ps. I can't open ports because my router is connected to ANOTHER router (where I don't have administrator access on).
Re: Upload through http?
Posted: Tue Nov 05, 2013 12:45 am
by Dutch_Master
HeroS_NL wrote:ps. I can't open ports because my router is connected to ANOTHER router (where I don't have administrator access on).
Hate to be pedantic, but isn't that how the web is build? ;)
You could try VPN, i.e. tunnelling via ssh or similar, for remote access. Fairly easy, as you have access to the first router (your own) :)
Posted: Tue Nov 05, 2013 7:05 am
by HeroS_NL
I can't access SSH or something either by accessing the external IP. I do have acces to the internet though.
I see your point, but my problem is that my (wifi)router is connected to ANOTHER (wifi)router. This router where I'm connected to is from someone else in the house which I may not adapt some things to. Therefore I cannot portforward..
(so I don't have acces to the FIRST router)
Posted: Thu Nov 07, 2013 11:57 pm
by HeroS_NL
Bump! Anyone who knows this information?
Posted: Fri Nov 08, 2013 12:12 am
by redhawk
HeroS_NL wrote:I can't access SSH or something either by accessing the external IP. I do have acces to the internet though.
If you cannot access the router to "port forward" then how are you going to connect to your Pi to upload with http??
Richard S.
Posted: Fri Nov 08, 2013 1:57 pm
by HeroS_NL
Richard S.
Well, since all the devices who connect to my router have access to the internet, thus http, it will be the same for the raspberry Pi right?
On connecting myself with the Pi, that will be a problem yes, but as long as I'm in the same network (at home) it won't be a problem?
Posted: Fri Nov 08, 2013 2:44 pm
by topguy
Two devices on the same LAN will not be blocked by any router.
Two devices on different LAN when neither can unblock any ports, could use a storage space (dropbox for example) on the internet to exchange information.
Posted: Sat Nov 09, 2013 6:02 pm
by HeroS_NL
topguy wrote:Two devices on the same LAN will not be blocked by any router.
Thank you! This was the information I needed :)
