jbach
Installing OSC
Thu Oct 31, 2013 7:11 pm
I need to enable TouchOSC on a mobile device to communicate with a Rasberry Pi. So first step is getting OSC installed on the Pi.
To use 'SimpleOSC' http://www.ixi-software.net/content/bod ... d_osc.html
do I first need to install PyOSC?
Is there a tutorial anywhere that walks thru the process for a Python-linux newbie?
Re: Installing OSC
Thu Oct 31, 2013 7:34 pm
There's no Raspbian package for PyOSC so you're going to need to clone it from the Git repo then install it by running the setup program.
Start with
sudo apt-get install git
if you don't already have git installed.
Then pick up a copy of the PyOSC code:
cd /tmp
git clone git://gitorious.org/pyosc/devel.git
Installation is then quite simple :
cd devel
sudo ./setup.py install
honsey
Re: Installing OSC
Sat Nov 09, 2013 6:22 pm
I'm running into problems trying to use OSC within python scripts.
Installed pyOSC by cloning from git into ~/devel and running the installer
This gives me the following output
running install
running build
running build_py
running install_lib
running install_egg_info
Removing /usr/local/lib/python2.7/dist-packages/pyOSC-0.3.6_6382.egg-info
Writing /usr/local/lib/python2.7/dist-packages/pyOSC-0.3.6_6382.egg-info
Running the testbench.py to listen to my OSC server
python testbench.py -l 192.168.0.199:7000
This throws an error after (trying to?) instantiating the OSC server:
Instantiating OSCClient:
OSCClient v0.3.6-6382 connected to osc://Dose.home:7000
Instantiating OSCServer:
  File "testbench.py", line 362, in <module>
    s = OSCServer(listen_address, c, return_port=listen_address[1])
  File "/home/pi/devel/OSC.py", line 1876, in __init__
    UDPServer.__init__(self, server_address, self.RequestHandlerClass)
  File "/usr/lib/python2.7/SocketServer.py", line 419, in __init__
    self.server_bind()
  File "/usr/lib/python2.7/SocketServer.py", line 430, in server_bind
    self.socket.bind(self.server_address)
  File "/usr/lib/python2.7/socket.py", line 224, in meth
    return getattr(self._sock,name)(*args)
socket.error: [Errno 99] Cannot assign requested address
Whats wrong with my installation?
Hope somebody can help me — Thank you + Bye,
Hans
nolman
Re: Installing OSC
Thu Jan 30, 2014 8:51 am
i would also be very interested in getting osc to work with the raspberry pi. Any tips very welcome!
thanks.
Angelus88
Re: Installing OSC
Thu Jan 30, 2014 9:36 am
Try with sudo
sudo python testbench.py -l 192.168.0.199:7000
If it doesn't work, is "192.168.0.199" the IP address of your RPi? If so try
python testbench.py -l 127.0.0.1:7000
or again
sudo python testbench.py -l 127.0.0.1:7000
and make sure port 7000 is free!!
Return to “Beginners”
