lazarus78
Command(s) to get just your IP?
Tue Oct 29, 2013 6:45 pm
I need a command or commands to return just my local IP, nothing else. Its rather amazing how hard it is to do this, nothing i found in my searches worked or returned more then just the address.
karlkiste
Re: Command(s) to get just your IP?
Tue Oct 29, 2013 6:59 pm
Look in the file /etc/rc.local of raspbian os.
Tue Oct 29, 2013 7:03 pm
How about:
  1. `ifconfig wlan0 | grep 'inet addr'
  2. `ip -4 addr` | awk '{print $4}'
  3. host `hostname` # the backticks are important
pick your poison.
You may need to run the output from those commands through grep, sed or awk to strip out just the address. I'll leave that as an exercise. It's a good skill to learn awk.
This is a doctor free zone.
lazarus78
Wow... that simple...
hostname -I
DougieLawson wrote:How about:
  2. `ip -4 addr`
pick your poison.
1 and 3 don't work. 2 doesn't return just the IP as I needed.
Tue Oct 29, 2013 7:11 pm
lazarus78 wrote:Wow... that simple...
hostname -I
Beware `hostname -i` or `hostname -I` doesn't work cleanly on my system
[email protected] ~ $ hostname -i
2001:xxxx:xxxx:2e00:821f:2ff:fe68:c6af 10.1.1.7
[email protected] ~ $ hostname -I
10.1.1.7 2001:xxxx:xxxx:2e00:821f:2ff:fe68:c6af
because my RPi is running both IPv4 & IPv6.
lazarus78
Tue Oct 29, 2013 7:49 pm
Makes sense. The systems I am using it for are all running IPv4 only apparently. (CentOS, Debian, and Raspbian)
thanks for the warning though.
