Sound in Scratch
Posted: Tue May 15, 2012 7:36 am
by blogmywiki
Apologies if this has been answered elsewhere - I have searched and couldn't find anything on this precise topic.
I've got sound working on my RasPi - I can play MP3s in VLC and the media player included with the Debian Squeeze image just fine through my TV over HDMI. But I can't get any sound out of Scratch - I either get silence or an 'invalid sound format' message from Scratch. Any ideas?
Re: Sound in Scratch
Posted: Wed May 23, 2012 2:02 pm
by Sharks58uk
I have the same issue.
Here's how I fixed half the problem. This worked for me but I really don't know what I'm doing - I'm not familiar with debian or smalltalk so I don't recommend you try this ;)
I found a script that I assume is written in smalltalk that runs when you run scratch. It's at /usr/bin/scratch
I removed code that *looks like* it's setting up the sound, and added code that sets the sound to use alsa drivers - which I installed on my system when I was trying to get sound to output to the jack rather than the default auto select (I'm using HDMI it a monitor with a separate audio in).
I changed the lines that say:
if pulseaudio - - check 2>/dev/null ; then
     VMOPTIONS="$VMOPTIONS -vm-sound-oss"
     if padsp true 2>/dev/null ; then
          WRAPPER=padsp
     fi
fi
to say this instead
#if pulseaudio - - check 2>/dev/null ; then
#    VMOPTIONS="$VMOPTIONS -vm-sound-oss"
#     if padsp true 2>/dev/null ; then
#          WRAPPER=padsp
#     fi
#fi
VMOPTIONS="$VMOPTIONS -vm-sound-alsa"
The # symbols comment out the old code so it's ignored.
Now I can make the cat meow (i.e. scratch plays the silent files) but it still won't load some of the files included in scratch.
Hope this helps, let me know if you find a better solution!
Simon
Posted: Wed May 23, 2012 4:31 pm
by jgearing
[quote="Sharks58uk"]I have the same issue.
you are kidding, if you don't know what you're doing then I'm in real trouble
Took me an hour to work out where to do the typing, anyway it works a treat for me, many thanks
Re the audio socket, a man elsewhere says it has to be amplified to get any sound from it
Thanks again
JG
Posted: Wed May 23, 2012 5:03 pm
by aceface57
jgearing wrote:
Sharks58uk wrote:I have the same issue.
Thanks again
JG
I've had sound coming out of it just fine into my headphones (in ear style) playing from the default audio player in debian. No idea on how to get scratch working for you though!
Posted: Sun May 27, 2012 5:27 pm
by DavidMS
I have the same problem - probably a stupid question but I do not seem to have permission to make this change, am I missing something. I am trying to make the change from using Leafpad, I have tried to change the permissions but seemingly I do not have permission to to this !
Posted: Fri Jun 01, 2012 7:10 am
by nuttingcdef
You may need to log in as root to do this - not as pi.
If you log in as pi, you can set the root password using 'sudo passwd root'. Then logout and log in again as root.
Posted: Sat Jun 30, 2012 2:44 pm
by DavyC
Hi
I have the same problem.
Please could you tell me the file path where I need to comment out the above code.
Davy
Posted: Sat Jun 30, 2012 10:53 pm
by texy
He said it was :
[quote]I found a script that I assume is written in smalltalk that runs when you run scratch. It's at /usr/bin/scratch[\quote]
T.
Posted: Sun Jul 01, 2012 8:50 am
by DavyC
Hi
Thanks for pointing that out - completely missed when I read it the first 5 times.!
The solution worked perfectly.
Much appreciated.
Regards
Dave
Posted: Thu Jul 26, 2012 6:38 pm
by Clifford
It took me a while (and some research) to figure out why anyone would assume this was Smalltalk - seemed like the least likley choice. It is in fact just a Bash shell script.
Any how in my Debian Wheezy image /usr/bin/scratch is an empty folder. The actual name of the file would be useful, or if anyone knows its new location?
Posted: Sun Jul 29, 2012 4:25 pm
by RandomCoder
Clifford wrote:It took me a while (and some research) to figure out why anyone would assume this was Smalltalk - seemed like the least likley choice. It is in fact just a Bash shell script.
I'm using the same Debian Wheezy image and I can confirm this works.
You just need to type...
sudo nano /usr/bin/scratch
Then modify the lines of code as listed in the second post. The lines appear about three pages down the file.
Regards,
RandomCoder
Posted: Fri Aug 03, 2012 5:53 pm
by Clifford
Doh! I was looking for a directory called /usr/bin/scratch and was wondering why @Sharks58uk was not being very specific about the file name! That is how I interpreted
Thanks.
Posted: Mon Aug 06, 2012 10:33 am
by jasedotcom
Works a treat
Posted: Sun Aug 19, 2012 4:34 am
by vn00325
To those who had sound trouble even after following the posts here (changing the VMOPTIONS to use alsa and doing the amixer cset numid=3 2. Similar with many people in this and other posts, HDMI sound works with aplay or mpg123 test or mplayer playing wave/mp3 files - but not with scratch.
What I did to troubleshoot was start scratch manually in a x-term window with the alsa sound:
/usr/lib/squeak/4.47-2357/squeakvm -encoding UTF-8 -vm-display-x11 -xshm -plugins /usr/lib/scratch/plugins/:/usr/lib/squeak/4.47-2357/ -vm-sound-alsa /usr/share/scratch/Scratch.image
Once scratch was loaded, I tried to execute a sound (meow) and I got the error logged in the xterm:
soundStart: snd_add_pcm_handler: Function not implemented
So I thought there might be some sort of a conflict in sound drivers. Out of curiosity, I looked at my processes and saw that the pulseaudio daemon was also running. I killed pulseaudio
pulseaudio --kill
After the pulseaudio was killed, tried the scratch meow again and it worked. I'm not a linux expert, so I don't know why scratch using also does not work with the pulseaudio daemon is started. I took out the pulseaudio from being started during boot by moving the pulseaudio start script out of the /etc/init.d. All sound seems to be working fine now.
Hope this helps out those with scratch sound over HDMI issues.
Posted: Thu Aug 23, 2012 9:33 am
by tonygo2
Thank you very much for finding a fix to the problem which has been bugging me from the first time I tried Scratch on my Pi. All now working properly on first and latest versions of OS using a DVI monitor and analogue sound via an amplifier. Great!
Posted: Sun Aug 26, 2012 10:26 am
by galoisgroup
Commenting out statements relating to pulseaudio from /usr/bin/scratch and adding the extra command
seems to work in Scratch but disables sound in Music Player!
Any thoughts?
Posted: Fri Aug 31, 2012 9:05 pm
by lightnin
Hi all! I'm a member of the Scratch Team who has done some work on the linux packaging. I have a couple of questions / info that might be helpful to those who are doing the packaging for rPi.
Does Raspbian use pulseaudio?
If it does, then it's probably best to use the pulseaudio driver. The current debian package uses OSS in a pulsewrapper, but I think that's because Debian doesn't use pulse (?)
You can use Alsa for playback, but the sound record functions don't often work and result in a "pink box" crash on Scratch. That's what I'm seeing when I run Scratch on my rPi with ALSA sound driver.
Pulse is supposed to emulate ALSA, so it should be fine to run Scratch with ALSA on pulse. But Pulse doesn't emulate the asynchronous ALSA functionality that Scratch needs. So, at least on Ubuntu (and I assume other distros that use pulse), it's best to use the squeak pulse audio plugin. It has recently been updated so it will work properly with 64 bit systems -- (previously it caused seg faults). Not sure if it's compatible with ARM. If rPI doesn't use pulse, then ALSA should work well AFAIK. Not sure why it's pink boxing on sound records.
Devs / packagers - I'm cc'ed on some emails about rPi and Scratch, so if you have questions, drop me a line and I'll clarify. Or use the contact us link on the Scratch website.
Love me some pi! (Makes a great home webserver!)
Amos
Scratch Community Coordinator
Posted: Fri Aug 31, 2012 9:22 pm
by asb
Hi folks, I modified the /usr/bin/scratch launcher script a little while ago so the vm-sound-alsa plugin is used. You'll have this version if you have the latest 2012-08-16-wheezy-raspbian.zip image. If you have an older Foundation Raspbian image, just do `sudo apt-get update && sudo apt-get install scratch`.
Posted: Sun Sep 09, 2012 3:23 pm
by galoisgroup
My grandson has the Raspberry Pi so I can't test it out but, on behalf of many,
Thanks for looking into this problem.
Posted: Sun Nov 11, 2012 9:47 pm
by diyduffer
amending /usr/bin/scratch
pay attention to grammar , punctuation and spaces.
Worked for Me, My son is very happy and now enjoying his firs :shock: t programme.
Posted: Thu Jan 10, 2013 7:21 am
by brianjester
Sharks58,
The fix mostly worked for me as well. (forcing line 89 of /usr/bin/scratch: VMOPTIONS='$VMOPTIONS -vm-sound-alsa')
The exceptions were:
1. On a subsequent launch, I noticed that MP3 sounds (Cat.MP3) didn't play, and WAV sounds (Bird.WAV) did.
2. On a subsequent launch, the RaspberryPi hung (froze) when I attempted to play the Cat sound.
Brian Jester
Posted: Thu Jan 10, 2013 7:25 am
by brianjester
vn00325,
When I launched /usr/bin/scratch with a "-x" on the shebang line (line #1), I saw on the console:
snd_pcm_writei returned -1
This was after the fix to line 89 for "-vm-sound-alsa".
Brian Jester
