pistons4550
powering my model a
Tue Oct 22, 2013 2:39 am
Hi everyone
I want to have a battery power my raspberry pi model A through the USB port. Planning on getting a 9V battery connected to a UBEC to convert to 5V and connect that to the USB port. The thing is that I also have a wifi adapter I need to use with the USB port. Im wondering if I can get one of those split USB adapters so that I can use my wifi adapter and power the pi through the USB port without any problems. I have read about back power but Im wondering if that only pertains to hubs that receive their own power.
Hove
Re: powering my model a
Tue Oct 22, 2013 10:53 am
Why not power it through the normal micro USB power connector? Is there a good reason? Doing it that way would open up the single type A USB port for your dongle.
www.pistuffing.co.uk - Raspberry Pi and other stuffing!
pistons4550
Tue Oct 22, 2013 2:01 pm
You know what, my bad, I havent gotten my hands on the pi yet, I was taking care of the power supply for a project and I guess misread the pi A's features. Sorry guys
lazarus78
Tue Oct 22, 2013 5:48 pm
pistons4550 wrote:You know what, my bad, I havent gotten my hands on the pi yet, I was taking care of the power supply for a project and I guess misread the pi A's features. Sorry guys
If you havnt gotten yours yet, then I suggest getting a model B instead.
pistons4550
Tue Oct 22, 2013 7:31 pm
Thanks for the suggestion but its a group project for school and the choice was made by a different member
lazarus78
Tue Oct 22, 2013 8:18 pm
pistons4550 wrote:Thanks for the suggestion but its a group project for school and the choice was made by a different member
Well get a model B for yourself to mess with! XD
Good luck with whatever your project it. Pis are fun to play with.
pistons4550
Tue Oct 22, 2013 9:32 pm
Lol well this whole thing has got me hankering for some of my own side projects so I probably will
pistons4550
Wed Oct 23, 2013 4:47 am
Ok well I think I have a legitimate question this time. I need a power supply that will power the model a pi, motors on an RC car, and my custom PCB that takes in 3V. I have all the things I need to step down the voltage so that my stuff doesn't fry but im wondering if you guys could give me an opinion on using this
http://www.adafruit.com/products/248
since I already have a charger for AA batteries that would save me some trouble
karlkiste
Wed Oct 23, 2013 5:21 am
Go on, seems OK.
I'd like to give a little warning on Model A's USB port: I had trouble connecting USB pendrives. They lost connection after some minutes. Plugging a USB hub in between helps, even if it is an unpowered one. Don't know how WIFI works, though.
I've recently been powering a Model A like this: I took a powered USB hub, and shorted the diode which prevented the input to be powered. So, the hub gives power to the pi through the USB port. It's not a recommended way of powering the pi, but it's possible.
pistons4550
Wed Oct 23, 2013 3:15 pm
karlkiste wrote:Go on, seems OK.
Sounds like a cool thing to try out, but with my grade riding on this thing I wanna try the approach with the least amount of risk
pistons4550
Wed Oct 30, 2013 2:34 am
Ok so I got my parts in the mail and I tested my ubec with a 9V battery and didnt get out 5 volts, instead I got 5.25V. Is that extra .25 gonna be a problem?
Edit: the third one I tested is outputting 5.3 volts
ame
Wed Oct 30, 2013 4:16 am
pistons4550 wrote:Ok so I got my parts in the mail and I tested my ubec with a 9V battery and didnt get out 5 volts, instead I got 5.25V. Is that extra .25 gonna be a problem?
Unlikely. Wikipedia states the USB 5V supply line to have a range of +/- 0.25V. The voltage may drop a little bit with a load anyway.
karlkiste
Wed Oct 30, 2013 5:07 am
Most electronics states 5.5V or 6V as the upper working limit, and no damage is guaranteed up to 7V.
And: If you're measuring 5.3V... What does that mean? What's the accuracy of your meter? Some other (more expensive) meter would maybe display 4.983V. Accuracy "5%+1" digit means, that a real Voltage of 5.000V may be display a value of up to (5*1.05)=5,25V. If there's only one digit after the point, this may be rounded to 5.3V. Then, there's the "+1 digit", so a real voltage of 5.000V can even be displayed as 5.4V!
pistons4550
Wed Oct 30, 2013 1:03 pm
Alright sweet, thanks guys
pistons4550
Thu Oct 31, 2013 8:17 pm
Has anyone experienced problems using cheap micro usb cables to power their pi. I was gonna buy a 2 dollar one and cut it open to use the positive and negative wires to solder to my ubec
Return to “Beginners”
