Error on boot - NOOBS
Posted: Sun Oct 20, 2013 4:47 pm
by Gutbucket
Totally new to RPi. Exposed to LINUX through TouchPad Android install. All reminds me of DOS before Windows.
Using a Kingston 16GB, Class 10 SDHC card (SD10V/16GB - appears on list as working 1/2 the time based on user experiences).
Formatted using SDFormatter. NOOBS unzipped onto SD card (option for format size adjustment is ON). Put it in Pi & power it up.
After multi-coloured splash screen I get following message (see Pi boot error01.png).
Click on close and I'm brought to OS selection menu. Obvious problem is statement that memory available on card is 0 MB.
What's happened? Where am I? What of donuts?
Does this sound like SD card problem or have I missed something in setting up. When I select on-line help, it even accesses network and lets me surf.
Thanks in advance for any help.
Dave (AKA Gutbucket)
Re: Error on boot - NOOBS
Posted: Sun Oct 20, 2013 5:19 pm
by mahjongg
This is one of the brands and types of cards, that are most often imitated by cheap Chinese fake SD-cards makers, could be that you ran into such a fake card, especially if the heritage of the card is a bit obscure.
The error codes you get are certainly not normal.
a youtube clip about fake kingston 16GB, Class 10 SDHC cards http://www.youtube.com/watch?v=tzhDQwNqq5U
many fake cards even lie about their true capacity which sometimes is just a fraction of the promised capacity!
http://flashchiptech.wordpress.com/2011 ... emory-car/
Posted: Sun Oct 20, 2013 8:51 pm
by Gutbucket
Sorry. Here are error images. :
Pi Boot Error01.jpg (26.12 KiB) Viewed 1055 times
Pi Boot Error02.jpg (24.82 KiB) Viewed 1055 times
Pi Boot Error03.jpg (22.25 KiB) Viewed 1055 times
Posted: Mon Oct 21, 2013 4:50 pm
by rdb
Can you see if the error is repeatable?
Often when people see this error, reformatting the card as specified in the Quick Start Guide and re-installing the NOOBS files results in a working install.
Usually this is the fault of Windows' formatting tools not updating the second FAT.
Posted: Tue Oct 22, 2013 1:14 am
by Gutbucket
Thanks for the pointers. :)
I did repeat the process a couple of times with the same result.
SD cards are legit according to Kingston.
I think I've tracked it down to my method of flashing NOOBs onto my SD card.
I'll re-format & re-flash & try again.
