Trooper11040
Making MP3 play 1 time on Python Script Bootup
Thu Oct 17, 2013 12:15 am
I have a python script already written, that uses 3 reed switches, and when my magnet runs over them, it makes a MP3 play. But is there any coding I could use, that when my script boots up (I have it running on the Pi's startup) that it can play an MP3 right at the start of the script one time? Thanks...hope that makes sense!!! Below is my code that I am using already successfully so far!
Dan
#!/usr/bin/env python
from time import sleep
import os
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.IN)
GPIO.setup(24, GPIO.IN)
GPIO.setup(25, GPIO.IN)
while True:
    if ( GPIO.input(23) == False ):
      os.system('mpg321 habs.mp3 -q &')
      sleep(10.0);
    if ( GPIO.input(24) == False ):
      sleep(10.0);
    if ( GPIO.input(25) == False ):
      sleep(10.0);
    sleep(0.1);
DeeJay
Re: Making MP3 play 1 time on Python Script Bootup
Thu Oct 17, 2013 6:45 am
Trooper11040
Fri Oct 18, 2013 4:44 am
I have the python script already running at boot. I just wanted to add the ability using my script, for an MP3 to play also at the time of boot within that script...
DeeJay
Fri Oct 18, 2013 7:18 am
Found this on http://raspberrypi.stackexchange.com/qu ... ith-python
I've checked that it works on an RPi with an mp3.
import pygame
pygame.mixer.init()
pygame.mixer.music.load("myFile.mp3")
pygame.mixer.music.play()
But pygame needs an x-windowed environment which you might not have at bootup. So the solution with mpg321 might be better for your needs?
texy
Fri Oct 18, 2013 8:12 am
DeeJay wrote:Found this on http://raspberrypi.stackexchange.com/qu ... ith-python
import pygame
pygame.mixer.init()
....pygame does not need X-windows to run in my experience. I have a startup python program that I use to test my display boards and X isn't entered, but it uses pygame for the graphics.
Texy
