Tv Catchup
Hi just installed tvcatch up on raspberry pi using openelec xbmc enabled says ok but when I run it it says script error on plugin how do I fix it please.
Re: Tv Catchup
Is it the froyo version of the script? If so, try the other version
Re: Tv Catchup
were do i find other version please
Re: Tv Catchup
How did you install the plugin? I used the official tvcatchup repo. There are a few different versions in there
Re: Tv Catchup
fusion - video = world = british two versions normal and epgvibez wrote:How did you install the plugin? I used the official tvcatchup repo. There are a few different versions in there
funny used same plugin in raspbmc and it works must be openelec issue
version was tvcatchup staff version
