HyperGoat
WiFi issue (FIXED) and dpkg error (not fixed)
Wed Oct 09, 2013 11:53 pm
***EDIT***
I HAVE FIXED BOTH OF THESE ISSUES USING THESE FIXES:
I fixed the internet error with my ralink adapter using
sudo nano /etc/network/interfaces
then i added the lines:
auto wlan0
iface wlan0 inet dhcp
(tab)wireless-essid YourEssID
(tab)wireless-mode managed
(tab)wireless-key xxxxx
The DPKG error i mention slightly later in this thread turns out to be a result of a corrupted image. I had to redownload a NEW image and reformat and burn to get it to work. I suppose the first one i downloaded was corrupted.
***EDIT***
Firstly I'm a noob to linux, so i need to be walked through setting up the above wifi dongle.
It is listed in lsusb as a Ralink rt5370, but it isnt listed in the wifi config program.
What should I do?
I've gone through a few tutorials which edit some config files via the terminal, but I don't seem to be getting anywhere. I can provide info as needed.
SirLagz
Re: WiFi with a Tenda 311MI
Thu Oct 10, 2013 4:53 am
Some more information would be useful.
Which OS ?
Are you using a powered hub ?
Have you done a full update of the OS ?
What tutorials did you try to follow ? What were the results when you followed the tutorials ?
HyperGoat
Thu Oct 10, 2013 10:17 am
SirLagz wrote:Some more information would be useful.
Which OS ?
Rasbian
Yes, a four port 2.5mA powered hub
I ran apt-get update and install, but I have no internet so it did nothing. I am running the latest version of rasbian wheezy available on the downloads page at raspberrypi.org though.
SirLagz
Thu Oct 10, 2013 1:37 pm
Can you paste the current contents of /etc/network/interfaces ?
Also the output of lsusb and ifconfig -a
HyperGoat
Fri Oct 11, 2013 3:04 am
Acctually i got it working, so sorry for the bother.
Now to only problem is that i get an error when using apt-get install or remove. The error has something along the lines of :dpkg: unrecoverable fatal error, aborting. I'm also unable to connect to the pi store. It says 'user interface not loaded.' (i think, i cant get on my pi right now).
I think it may be the way i burned my image. With the image writer reccomended on the downloads page, what should my settings be? I set it to quick and size adjustment on.
SirLagz
Fri Oct 11, 2013 3:52 am
Best to get onto the Pi and paste the exact error message.
I would recommend at least a "apt-get clean && apt-get update" and see what happens afterwards
HyperGoat
Fri Oct 11, 2013 2:59 pm
SirLagz wrote:Best to get onto the Pi and paste the exact error message.
Here is the output for apt-get install xxxxx:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
thrust
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 115 kB of archives.
After this operation, 347 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main thrust armhf 0.89c-3.5 [115 kB]
Fetched 115 kB in 1s (90.4 kB/s)
dpkg: unrecoverable fatal error, aborting:
syntax error: unknown group 'crontab' in statoverride file
E: Sub-process /usr/bin/dpkg returned an error code (2)
The sudo apt-get clean && sudo apt-get update run, but they dont seem to fix anything.
HyperGoat
Sat Oct 12, 2013 10:27 pm
apt-get upgrade Also produces a similar error, so help is a bit urgent. Thanks in advance though! :mrgreen:
SirLagz
Re: WiFi issue (FIXED) and dpkg error (not fixed)
Mon Oct 14, 2013 1:36 am
perhaps look for a file named statoverride and paste the contents in here.
I don't have a statoverride file, so I'm not sure where it is...
HyperGoat
Mon Oct 14, 2013 1:38 am
I'll be able to look for the file tommorrow,but for now can you say if the way i configured my wireless might have anything to do with it?
I used this tutorial:
http://raspberry-pi-notes.blogspot.com/ ... ongle.html
Starting from step 6.
Also, if you look at the error it says:
And:
Surely 115 kb or 347 kb cant be the real file size? They are surely too small.
Anyway ill post the file contents in about 16 hours, but I really have no clue what any of this means.
SirLagz
Mon Oct 14, 2013 3:43 am
Do you have enough free space ?
HyperGoat
Mon Oct 14, 2013 11:02 pm
Here are the contents of stateoverride (I found it in var/lib/dpkg):
root crontab 2755 /usr/bin/crontab
I do have enough space btw
And when i sudo nano that there crontab file, i get a bunch of ascii characters that look like the matrix had a baby
SirLagz
Tue Oct 15, 2013 12:48 am
Remove the line and try again ?
HyperGoat
Tue Oct 15, 2013 12:55 am
SirLagz wrote:Remove the line and try again ?
Now it says this after the 'after this operation 347kb of additional disk space will be used':
dpkg: unrecoverable error, aborting:
syntax error: invalid uid in statoverride file
E: Sub-process /usr/bin/dpkg returned error code (2)
SirLagz
Tue Oct 15, 2013 2:42 am
put the line back in, change crontab to root ?
HyperGoat
Tue Oct 15, 2013 2:50 am
SirLagz wrote:put the line back in, change crontab to root ?
So as
root crontab 2755 /usr/bin/root
root root 2755 /usr/bin/crontab
root root 2755 /usr/bin/root
Which one?
SirLagz
Tue Oct 15, 2013 3:11 am
So as
Which one?
sorry, the second one
HyperGoat
Tue Oct 15, 2013 3:19 am
I shall do that, but I live on the east coast of the US so its midnight where I live. However I shall try this out and get back to you in 6 hours before I leave for classes.
Thanks again btw :mrgreen:
HyperGoat
Tue Oct 15, 2013 7:37 pm
The output now was the same as before, except now the syntax error is:
Unknown group 'root' in statoverride file
HyperGoat
Wed Oct 16, 2013 12:04 am
http://ubuntuforums.org/showthread.php?t=186487
that's a thread i found about ubuntu with what seems like the same problem.
Could this(that thread's info) be translated into rasbian-commands so that i can fix my similar error?
SirLagz
Wed Oct 16, 2013 1:56 am
You can use the same commands in that thread in raspbian, so give it a shot !
HyperGoat
Wed Oct 16, 2013 2:19 am
What do I have to change to make it work with my crontab error? For example, how would I translate the following to my situation?
I orinally saved /etc/group as /etc/group.default and then copied the group file from my old installation.
After reaching this problem and reading this forum post I noticed the error here states "unknown group `root`, where mine said `mlocate`. When did this:
# cat /etc/group.default |grep mloc
mlocate : x : 106 :
(I had to put spaces in above to stop text being converted to a smiley)
it was clear that I needed to put this 'mlocate' group back onto the system.
To fix it I did:
`cat /etc/group`
selected the groups I wanted to preserve for the new installation and copied those lins to the clipboard (user created groups are usually >1000
`cp /etc/group.default /etc/group`
`nano /etc/group`
pasted the lines into the bottom of the file and saved the new /etc/group
ran apt-get again and it's working again
HyperGoat
Fri Oct 18, 2013 1:12 am
Btw the contents of /etc/group is a bunch of squares on the firt line, followed by this line:
Indiecity:x:1000:pi
HyperGoat
Fri Oct 18, 2013 1:39 am
So I went into /etc/group and added the following group after using my substandard linux knowledge to vaguely interpret that post on the ubuntu forums I mentioned. I added the following line, thinking that it had to be there to give me some sort of permission for crontab:
[code]
crontab:x:1000:pi
[/code]
So now the entire /etc/group file looks like:
[code]
indiecity:x:1000:pi
crontab:x:1000:pi
[/code]
The indiecity thing was already there btw, I just used the number 1000 as a guideline ( i dont even know what it means.
Anyways, I must have made some prograss because I ran sudo reboot and the following was output when I ran sudo apt-get install thrust:
[code]
[email protected] /etc $ sudo apt-get install thrust
thrust
0 upgraded, 1 newly installed, 0 to remove and 31 not upgraded.
Need to get 0 B/115 kB of archives.
Selecting previously unselected package thrust.
files list file for package 'python-pifacecommon' is missing final newline
[/code]
You'll see that the 'Selecting previously unselected package thrust.' is new, as is the error mentioning python-pifacecommon. I though perhaps this was only a problem with this packages, so I ran sudo apt-get upgrade which outputs:
[code]
[email protected] /etc $ sudo apt-get upgrade
The following packages will be upgraded:
cups-bsd cups-client cups-common curl dpkg dpkg-dev ghostscript gnupg gpgv
idle initscripts libaudio2 libcups2 libcupsimage2 libcurl3 libcurl3-gnutls
libdpkg-perl libgs9 libgs9-common libsmbclient libsystemd-login0
libwbclient0 libxml2 python python-minimal samba-common smbclient sysv-rc
sysvinit sysvinit-utils tzdata
31 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/21.1 MB of archives.
After this operation, 572 kB disk space will be freed.
Do you want to continue [Y/n]? y
Extracting templates from packages: 100%
Preconfiguring packages ...
[/code]
Any idea on what to do next?
koshmarny
Fri Oct 18, 2013 1:30 pm
It seems, like
/var/lib/dpkg/info/python-pifacecommon.list
file is corrupted. It should be a text file with list of files to install.
Try to move it, like
sudo mv /var/lib/dpkg/info/python-pifacecommon.list{,.bak}
and then conitnue your upgrade.
