Page 2 of 5
Re: Howto: Disable Screen Saver In Raspbian
Posted: Sun May 31, 2015 3:17 pm
by rosignol
Thanks Jorgen I can see from other posts that nano would work too but as you will see from my updatad post I got there using the apt-get xscreensaver option
thanks for answering though
much appreciated
Rosignol
Posted: Sun May 31, 2015 3:58 pm
by Krassegrand
That was new to me!
Thank You!
J├Ârgen
Posted: Thu Jul 23, 2015 6:48 am
by DerberMohikaner
That's it!
Thank you VERY, VERY much.
Perfect
Ben
Posted: Fri Nov 27, 2015 12:38 am
by Fenhl
I have tried following the instructions posted here to disable the text terminals (ctrl-alt-1 etc) from blanking after a few minutes, but they were ineffective. Has any of this changed with jessie? Does anyone know a working method?
Posted: Sun Dec 13, 2015 12:49 am
by klricks
Fenhl wrote:I have tried following the instructions posted here to disable the text terminals (ctrl-alt-1 etc) from blanking after a few minutes, but they were ineffective. Has any of this changed with jessie? Does anyone know a working method?
Try this: viewtopic.php?f=63&t=125863
Posted: Sun Dec 13, 2015 7:50 pm
by Fenhl
Thanks, but I already fixed it with help from the #raspbian IRC channel. The solution was to add the following to the zshrc:
if [[ "$TERM" == "linux" ]]; then
    setterm --blank 0
fi
Posted: Sun Jan 17, 2016 11:03 am
by Bosse_B
I simply MUST get rid of this stupid screen blanking too. Is there no GUI window where such things can be configured?
I have Raspbian Jessie (Nov 2015) and it blanks the screen after a very short time.
In thus thread are so many different solutions and I get very confused...
What is the correct way to actually stop the blanking from happening on Raspbian Jessie????
What is zshrc as mentioned above? Surely there must be a path to it if it is a file?
Does xscreensaver work in Jessie? It was mentined here before Jessie was released...
The link above leads to a thread about the console, but I am talking about the GUI screen that gets black after a short time.
EDIT:
I installed the xscreensaver and then I found a new app in the Preferences submenu for the screensaver.
It has a selection for display mode on the first (left) tab where one can disable the screensaver altogether.
And it works in Jessie! All is now fine. :lol:
Posted: Thu Feb 04, 2016 1:02 pm
by rogerman
The only reliable way to totally disable screensaver that I have found is using xorg.conf.
This worked for me:
sudo nano /etc/X11/xorg.conf
Add this section:
Section "ServerFlags"
        Option          "BlankTime"     "0"
        Option          "StandbyTime"   "0"
        Option          "SuspendTime"   "0"
        Option          "OffTime"       "0"
EndSection
And also:
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
Add to autostart this lines:
@xset s noblank
@xset s off
@xset -dpms
Worked on X.Org X Server 1.12.4 version.
Hope this helps!
Posted: Mon Apr 18, 2016 8:16 pm
by Gammon
rogerman wrote:The only reliable way to totally disable screensaver that I have found is using xorg.conf.
This worked for me:
Add this section:
EndSection
And also:
@xset s noblank
@xset s off
@xset -dpms
Hope this helps!
Thanks! I've been having this same problem for a while. I had tried the autostart settings in all 3 locations (both /etc/xdg/xsession/ locations and ~./config/lxsession/LXDE-pi/) and it still wasn't working. Adding the xorg.conf file did the trick!
Posted: Wed Apr 20, 2016 1:18 pm
by Alexandre34
Just for info:
1) In my raspian jessie, the autostart file is in /home/pi/.config/lxsession/LXDE-pi
The files in /etc/xdg... seems to be obsolete..
I have add the following lines:
@xset s noexpose
@xset s noblank
@xset s off
@xset -dpms
You can check if the settings have been done with this command:
xset q
2) xscreensaver works fine, but now put a big splash screen during a few seconds asking to update the version !
Posted: Wed Apr 20, 2016 1:21 pm
by Rive
Here is how to turn off screen blanking, enable lock screen capability from keyboard shortcut, etc, using "light-locker":
viewtopic.php?p=961360#p961360
xscreensaver is garbage. Annoying popups, lockscreen broken (and doesn't use the debian/raspbian login), and the handful of screensavers that are selectable suck.
The author has also asked debian to remove it:
https://www.reddit.com/r/linux/comments ... remove_it/
Word from the author:
I stand by my words here: If you are considering removing this warning, then I ask that instead, you remove the XScreenSaver software from Debian entirely. I believe Gnome-Screensaver will be more to your liking anyway.
/* If you are in here because you're planning on disabling this warning
before redistributing my software, please don't.
I sincerely request that you do one of the following:
1: leave this code intact and this warning in place, -OR-
2: Remove xscreensaver from your distribution.
I would seriously prefer that you not distribute my software at all
than that you distribute one version and then never update it for
years.
I am *constantly* getting email from users reporting bugs that have
been fixed for literally years who have no idea that the software
they are running is years out of date. Yes, it would be great if we
lived in the ideal world where people checked that they were running
the latest release before they report a bug, but we don't. To most
people, "running the latest release" is synonymous with "running the
latest release that my distro packages for me."
When they even bother to tell me what version they're running, I
say, "That version is three years old!", and they say "But this is
the latest version my distro ships". Then I say, "your distro
sucks", and they say "but I don't know how to compile from source,
herp derp I eat paste", and *everybody* goes away unhappy.
It wastes an enormous amount of my time, and kind of makes me regret
ever having released this software in the first place.
So seriously. I ask that if you're planning on disabling this
obsolescence warning, that you instead just remove xscreensaver from
your distro entirely. Everybody will be happier that way. Check
out gnome-screensaver instead, I understand it's really nice.
Of course, my license allows you to ignore me and do whatever the
fuck you want, but as the author, I hope you will have the common
courtesy of complying with my request.
Thank you!
jwz, 2014
Source
Posted: Mon May 02, 2016 11:32 am
by timmoore46
I might be able to bring some clues to ditching screensaver or at at least saming it !
I had a poke around in /usr/bin/
I found a file called sleep and 'rm' it. A tad bold and it made no difference.
I am using the 18th March 2016 Rasbian and fully updated it and upgraded it.
but to no avail after 10 minutes the screen went off...
I tried 'deanbayley' 6th of march 2016 solution of
sudo /usr/bin/xset s off
sudo /usr/bin/xset -dpms
sudo /usr/bin/xset s noblank
but to no avail... now xset might be a hidden file ? I did not see it on my prowl of that directory..
Have I missed something ?
But what I did find was:-
xdg-screensaver and associated files
Now I don't have the skills needed to make sense of it...Is there anyway of contacting the Raspian team to give us the information to turn screensaver off ?
No Ubuntu have a 'System Settings' list and the second item in is a window which allows the user to make the adjustments to screensave on/off setting so it can be done.
Don't know if any of this makes sense...
Tim
Posted: Thu May 05, 2016 8:50 am
by CompanionConcierge
Thanks this helped
Posted: Thu May 05, 2016 7:07 pm
by timmoore46
Lets hope someone cracks this problem. Should be trivial but Unix always have been very awkward animal when it comes to this sometimes unwanted feature...
Tim
Posted: Fri May 06, 2016 10:07 am
by davenull
I'm also interested to disable the screen saver completely, once and forever.
But reading through this topic I don't understand anything about how to do it now - perhaps the solution is just obscured by too many words written here.
Now is there a final solution with reasonable effort for setting it up?
Posted: Fri May 06, 2016 4:05 pm
by Rive
You just want it OFF? no darkening of screen (blanking) after 10 minutes (or custom time elapse)?, no powering off monitor?, no screen locking?
Then that It is easy (if you have previously installed anything like xscreensaver, or light-locker, remove it)
Then;
In Terminal
open:
sudo nano ~/.config/lxsession/LXDE-pi/autostart
add:
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
Select All (from above code), then right click 'copy', then in '/autostart', 'paste' so it looks like this:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
save with 'Ctrl' + 'x' key, then 'y', then 'enter'
then:
sudo reboot
You will reboot and you are done. ;) No screensaver, no screen blanking, no monitor power saving mode.
Posted: Fri May 06, 2016 4:24 pm
by davenull
thank you, yes, I just intended the screen always to be visible, no black screen, no screen power save mode.
I followed your instructions just right now, and I'm observing wht's happening... ;)
edit:
30 min passed, everything is still on
Thanks again! :)
Posted: Sun May 08, 2016 7:25 am
by Bosse_B
Rive wrote: 'select all', then right click 'copy', then scroll to bottom with down arrow key, then 'paste'
I am assuming that by "select all" you mean in the code section of your post and not inside nano, right?
Anyway, doing so adds 4 spaces to the front of each line. This may or may not have detrimental effects.
If you instead just select the lines in the code section, then use Ctrl-C to copy and then paste into the nano window there are no extra spaces added.
Posted: Tue May 10, 2016 10:28 am
by timmoore46
I have tried out :-
etc
and wow ! Massive thanks to the member Rive that posted the fix !!
(Mega error ! Now corrected Huge appologies to Rive from me)
I like nano a lot, my preferred method to save is
CTRL/o to write the changes
and
CTRL/x to quit back to Bash prompt
Hero status to davenull who put forward this very elegant fix !
A very very happy,
:D :D :D :D
Tim
Posted: Tue May 10, 2016 2:39 pm
by Rive
timmoore46 wrote: Massive thanks to the member davenull that posted the fix !!
You must be super confused. It is very easy to confuse the quotes, and responses. FYI, "davenull" was requesting an 'easy to implement' fix, he didn't provide any fix ;)
Here is his original post:
davenull wrote: I'm also interested to disable the screen saver completely, once and forever.
Posted: Tue May 10, 2016 2:45 pm
by davenull
davenull wrote:thank you, yes, I just intended the screen always to be visible, no black screen, no screen power save mode.
edit:
Thanks again! :)
You must be super confused. It is very easy to confuse the quotes, and responses. FYI, "davenull" was requesting a fix, he didn't provide any fix ;)
what fix?
viewtopic.php?f=91&t=57552&p=971373#p969057
it worked as it is!
Posted: Tue May 10, 2016 2:46 pm
by Rive
This fix...
davenull wrote:I followed your instructions just right now...
In Terminal
open:
add:
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
then:
sudo reboot
Posted: Tue May 10, 2016 2:48 pm
by davenull
now I am super confused.
This was your post, and I followed it, and it worked.
Which fix am I missing?
Or do you mean "patch" ?
Posted: Tue May 10, 2016 2:51 pm
by Rive
davenull wrote:now I am super confused.
Oh boy....
Another poster (quoted below for reference) thought that fix was provided by you, and was thanking you for providing it. I was informing him that he was confused and you were asking for a fix, not providing one.
Evidently the way this board does the quotes is very confusing.
Posted: Tue May 10, 2016 2:57 pm
by davenull
:idea: !
:geek:
+1
8-)
