runboy93
Re: Howto: Disable Screen Saver In Raspbian
Thu Jun 29, 2017 9:37 pm
bettersweeps wrote:After days of also dealing with this problem i have finally figured it out, so far the commands listed here will only disable it if you remember to use the bash command you design, or just put it into a loop. Here´s a 1 step fix and explanation as to why the first part has failed to work, first the code.
xserver-command=X -s 0 -dpms
the reason this hasn´t always worked is because the command has 2 parts to it, the first 1 you see in the lightdm.conf file is merely a trigger, moving further down you will find a second part same print smaller description. The first one is located under Seat Defaults, the second is located under [seatdefalts] both xserver-command=X commands need to written exactly as
for it to work. This doesn´t matter what you run your pi as, this will guarentee to disable the screen saver aka blanking aka idle mode, your screen will never blank, blink, pause, its not a loop hole. this is the real deal fix to the screen saver without needing any apps, and or mods.
Thanks!
Aluminum case for Raspberry Pi 3 (B+ model not supported!)
https://goo.gl/Dxp6fD
RPi 3 tweaks by runboy93
https://goo.gl/FU636b
Thu Jun 29, 2017 9:40 pm
adeel88 wrote:
klricks wrote:
adeel88 wrote:...Thanks for your prompt reply. Yes. It worked. Can I add my custom screensaver using 'xscreensaver'?
Yes but you have to install some more addons to xscreenaver.
See this thread: viewtopic.php?f=63&t=185313
Thanks. Sorry, one last thing can I add a simple black screen when user don't use the raspberry-pi or after specific idle time and when user tap on that it will show the last/original state of raspberry-pi?
I was under the impression that one of the screensaver modes is "blank screen only" ??
""understanding the theoretical, but not always the end goal""
My other Devices are the ChromeBit CS10, ChromeCast & Huawei Mate 10 Pro SmartPhone
adeel88
Fri Jun 30, 2017 10:26 am
After 2 hours of idle time my raspberry-pi turned off. I don't want to turn-off raspberry-pi even its idle for many hours. I just want a BLACK screen and whenever I tap it shows me Raspberry-pi original state. Can someone help me regarding this?
Fri Jun 30, 2017 11:27 am
adeel88 wrote:After 2 hours of idle time my raspberry-pi turned off. I don't want to turn-off raspberry-pi even its idle for many hours. I just want a BLACK screen and whenever I tap it shows me Raspberry-pi original state. Can someone help me regarding this?
xscreensaver has many options including power management, you appear to not have understood the configuration parameters:
https://www.jwz.org/xscreensaver/faq.html
klricks
Fri Jun 30, 2017 1:13 pm
The screensaver program cannot do that. The RPi was turned off by some other reason / person.
adeel88 wrote: I just want a BLACK screen and whenever I tap it shows me Raspberry-pi original state. Can someone help me regarding this?
From the default screen [Display Modes] tab..... Click the pull down menu next to [Mode:] and choose [Blank Screen Only].
Choose how many minutes to blank......
When the mouse is moved or a key is pressed the original live screen is restored as with all screen savers.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
Fri Jun 30, 2017 3:33 pm
xscreensaver has a power management option under "Advanced"
klricks
Fri Jun 30, 2017 5:05 pm
Yes but settings there do not work on a RPi. The RPi has no powersave or hibernate functions.
adeel88
Wed Jul 05, 2017 10:03 pm
I am using xscreensaver that shows a screensaver after certain idle time period which is fine. What I want another thing is to always remain the raspberry-pi TURN-ON, like what happened now is after 10 minutes screensaver shows which is good but after 4-5 hrs(approx) elapsed my raspberry-pi turn-off/shutdown then I again plug-in the cable and start pi again.
What I want is even when I come next day the screensaver shows (random/black) whatever BUT the raspberry-pi wouldn't turn off. When I tap on that it showed the last state. Can someone guide me?
paulsimmons
Re: STICKY: Howto: Disable Screen Saver In Raspbian
Tue Aug 29, 2017 10:26 am
I have followed the steps but still having issue to disable the screen saver in Raspbian. Any help would be appreciated.
klricks
Tue Aug 29, 2017 5:15 pm
What steps? What issues?
Try adding the following 3 lines to autostart:
@xset s noblank
@xset s off
@xset -dpms
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
OR
Install xscreensaver and set mode to [no blanking]
sudo apt-get update
sudo apt-get install xscreensaver
BlackPian0
Sat Sep 23, 2017 4:07 pm
# Raspbian Jessie
Add the following line to /etc/rc.local (on the line before the final exit 0)
$ sudo sh -c "TERM=linux setterm -blank 0 >/dev/tty0"
# Raspbian Wheezy
You can disable this by editing /etc/kbd/config and looking for
BLANK_TIME=30
and setting the blank time to 0 (which turns it off)
BLANK_TIME=0
RaspberryPiGuy1971
Sat Sep 30, 2017 7:48 pm
Have you installed xscreensaver?
george4896
Mon Jan 01, 2018 4:55 pm
Thanks for the guide that was helpful.
hela
Fri Mar 09, 2018 10:57 am
After a while of trial and error - lots of trial ... even more error ;-) - I found the solution to install XScreenSaver with
an deactivate it afterwards in preferences most convenient.
However, I skipped
sudo apt-get update
as my system seemed to be quite actual (official Raspberry Pi Kit).
Originally my autostart had a line #@xscreensaver -no-splash.
But obviously you have to start XScreensaver first so it can deactivate the screen blanking :P
Not other settings in the autostart regarding screen blanking seem to be neccesary (... so far).
billybangleballs
Wed Mar 21, 2018 4:54 pm
In 2018-03-13-raspbian-stretch the only thing that worked was to install xscreensaver and loads of other rubbish and then turn it off.
Other rubbish.
The following additional packages will be installed:
  gnome-mime-data libart-2.0-2 libauthen-sasl-perl libbonobo2-0 libbonobo2-common libbonoboui2-0
  libbonoboui2-common libencode-locale-perl libfile-listing-perl libfont-afm-perl libgail-common
  libgail18 libglade2-0 libgnome-2-0 libgnome2-common libgnomecanvas2-0 libgnomecanvas2-common
  libgnomeui-0 libgnomeui-common libgnomevfs2-0 libgnomevfs2-common libgnomevfs2-extra
  libhtml-form-perl libhtml-format-perl libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
  libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl libhttp-negotiate-perl
  libio-html-perl libio-socket-ssl-perl libjpeg-turbo-progs liblwp-mediatypes-perl liblwp-protocol-https-perl
  libmailtools-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl liborbit-2-0 libtimedate-perl
  libturbojpeg0 liburi-perl libwww-perl libwww-robotrules-perl miscfiles perl-openssl-defaults xscreensaver-data
If I wanted a screensaver, I'm sure I wouldn't mind the 40Mb of extra space, but it seems a bit excessive just to be able to not have one.
Why is the screen blanking enabled by default in the first place?
Return to “Beginners”
Who is online
Users browsing this forum: n67 and 23 guests
