shneor
"librasqaul3 " is missing final newline error 2
Sat Oct 05, 2013 9:37 pm
Tried again to install Synaptic and also firefox-sage. Both aborted with the same error message. Is there a fix for this?
Thx,
Shneor
confuseling
Re: "librasqaul3 " is missing final newline error 2
Sat Oct 05, 2013 11:07 pm
"librasqaul3" returns no hits apart from this thread.
How about pasting the full output of an attempt to install something, including the actual error..?
[edit - there is a "librasqal3", that must be what you mean. Still, the whole output would be useful.
That said,
# aptitude reinstall librasqal3
might work]
http://forums.debian.net
shneor
Mon Oct 07, 2013 4:09 am
Thx, I'll try that.
Shneor
shneor
Mon Oct 07, 2013 5:24 am
[email protected] ~ $ sudo aptitide reinstall librasqal3
sudo: aptitide: command not found
[email protected] ~ $ sudo aptitude reinstall librasqal3
E: Unable to open /root/.aptitude/config for writing - apt_init (5: Input/output error)
The following packages will be REINSTALLED:
librasqal3
0 packages upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/216 kB of archives. After unpacking 0 B will be used.
dpkg: unrecoverable fatal error, aborting:
files list file for package 'librasqal3' is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
A package failed to install. Trying to recover:
Oakham
Mon Oct 07, 2013 5:27 am
sudo apt-get is the command line
http://linux.die.net/man/8/apt-get
did you synch repositories first ?
Searching is easy, most questions have been asked before !
confuseling
Mon Oct 07, 2013 6:11 am
shneor wrote:...
That isn't good. Corrupt SD card? I see from your other thread you've been pulling the plug out to reboot. That'll do it...
Is that file readable? What's in it?
shneor wrote: files list file for package 'librasqal3' is missing final newline
http://www.linuxquestions.org/questions ... ne-271118/
Would seem to indicate that deleting
/var/lib/dpkg/info/librasqal3.list
then reinstalling the package might help, if you feel like rearranging deck-chairs
:D
scruss
Mon Oct 07, 2013 11:11 am
confuseling wrote:Corrupt SD card?
Sounds like it. "Missing final newline" is usually how corrupt cards announce themselves.
shneor
Wed Oct 09, 2013 5:46 pm
I do believe the card is partly corrupt. I do shutdown before pulling the power plug. In any case, I am now running off a USB flash drive, which seems to be faster. As I have lots of space, I've d'ld Firefox-sage, synaptic, gnash, etc. I'm surprised that this version of Firefox is so Google-centric, I really don't like that.
Thanks to all who responded, I appreciate your help.
Shneor
