cowasaki
GPS module
Thu Sep 26, 2013 2:10 pm
I'm trying to setup a GPS module. I've bought the right one and looked at this page:
http://blog.petrilopia.net/linux/raspbe ... s-working/
How to install USB GPS dongle to Raspberry Pi Raspbian Wheezy.
"I needed GPS on my Raspberry Pi to do some wardriving and I found Globalsat BU-353 GPS USB receiver SiRF III dongle which has worked perfectly."
First we have to install GPSD and GPS-Clients with apt-get:
apt-get install gpsd gpsd-clients
After that you could get gpsd working with it’s .conf file but I haven’t so I just use short script to get my GPS working:
pkill gpsd
gpsd -n -D 2 /dev/ttyUSB0
Save that example as gps.sh and give it enough rights:
chmod +x gps.sh
Now run that script and test if your GPS is working using cgps:
cgps -s
"You should shortly see some NMEA data and more location data like latitude, longitude, time and so on… If you get those to your screen your GPS is working OK."
I've got a completely fresh default wheezy installation and try typing the first line:
but get the response:
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
I've tried "su pi" but it makes no difference. Any ideas?
Dutch_Master
Re: GPS module
Thu Sep 26, 2013 3:25 pm
Try sudo instead of su.
sudo apt-get install gpsd gpsd-clients
cowasaki
Re: GPS module
Thu Sep 26, 2013 3:52 pm
Thanks I will try then wheni get home.
Whig
Re: GPS module
Fri Oct 04, 2013 8:20 am
Did you get GPS work with your raspberry pi?
Try to log in as a root and then try that apt-get install line again.
My projects and other stuff: http://www.petrilopia.net/
cowasaki
Re: GPS module
Fri Oct 04, 2013 12:42 pm
Thank you.
I am building a computer into my landrover so the GPS was really rather useful. I now have a screen which tells me that the GPS is working :D
cowasaki
Re: GPS module
Fri Oct 04, 2013 12:43 pm
Now I just need a UK navigation program :)
Return to “Beginners”
