Tue May 22, 2012 7:43 am
This wasn't your solution, but I thought I'd list it in case someone else was having difficulties with a login problem that I was having.
On the first login, the keyboard is set to UK (British) layout, which means that if you type "raspberry" on a non-english-layout keyboard you might get something else. My german keyboard has the Y and Z swapped. So in this case you need to use 'raspberrz' as the password, which will be entered as raspberry for the computer to read.
Subsequently you can change your keyboard layout. There is a link somewhere on how to do that. This caused my boot to go EXTREMELY slow when it hit the keyboard line, but not to worry. It does eventually bootup. After logging in you can use:
sudo setupcon
and this fixed the slow bootup.
