etek
syntax error in getting input
Wed Sep 04, 2013 12:16 pm
my very first program
# -*- coding: utf-8 -*-
import RPi.GPIO as gpio
gpio.setmode(gpio.BCM)
gpio.setup(17, gpio.IN)
while True:
    input_value = gpio.input(17)
    if input_value == False:
        print('The button has been pressed...')
        while input_value == False:
Error
First line is automatically included when i run my prog
and my syntax error is
File "button.py" , line 8
SyntaxError : invalid syntax
//help me :|
DeeJay
Re: syntax error in getting input
Wed Sep 04, 2013 2:45 pm
Check the layout of the program script - indentation is critical with python.
Look very carefully at what happens after "while True:" and before " input_value = gpio.input(17)"
etek
Thu Sep 05, 2013 1:10 pm
Thanks! the problem is with indentation, but still i could not get the desired output.
DeeJay wrote:Check the layout of the program script - indentation is critical with python.
DeeJay
Thu Sep 05, 2013 4:13 pm
My experience with your script -
[email protected] ~ $ cat etek.py
while True:
When run, gives -
[email protected] ~ $ sudo python etek.py
(I have nothing connected to the gpio header on the RPi.)
etek
Wed Sep 11, 2013 9:45 am
Hey there I got my output after I changed my 10k resistor to 1k.
vijay_nav
Sat Oct 19, 2013 4:07 am
i am facing an error in 17 line this syntax error is
if GPIO.input(8)
please help me
# Import the required modules.
import RPi.GPIO as GPIO
import time
# Set the numbering sequence of the pins, then set pins ten and twelve to output, and pin eight to input.
GPIO.setmode(GPIO.BOARD)
GPIO.setup(10, GPIO.OUT)`
GPIO.setup(12, GPIO.OUT)
GPIO.setup(8, GPIO.IN)
# Turn both of the LEDs off.
GPIO.output(10, True)
GPIO.output(12, True)
# The SwitchState variable is 1 if the button is pressed, and 0 otherwise. LEDState is 0 when off, 1 when red, and 2 when green.
SwitchState = 0
LEDState = 0
while 1:
if GPIO.input(8)
# When the LED is off, keep the green LED off, turn the red one on, then change the state of the LED to reflect that it is red, and wait one second.
if LEDState == 0
GPIO.output(12, False)
LEDState = 1
time.sleep(1)
# When the LED is red, turn the green LED on, turn the red one off, then change the state of the LED to reflect that it is green, and wait one second.
elif LEDState == 1
GPIO.output(10, False)
LEDState = 2
time.sleep(1)
# When the LED is green, turn it off, then turn the red one off, then change the state of the LED to reflect that they are all off, and wait one second.
elif LEDState == 2
LEDState = 0
time.sleep(1)
DeeJay
Sat Oct 19, 2013 8:41 am
vijay_nav wrote:i am facing an error in 17 line this syntax error is
if GPIO.input(8)
please help me
That line is incomplete.
Have a look at some Python documentation -
http://www.tutorialspoint.com/python/python_if_else.htm
http://docs.python.org/2/tutorial/controlflow.html
[Since Python relies on indentation as part of its syntax, please post sample code within a CODE block by using the [
][/b] box at the top of the message editor screen.]
