Re: How to resize Debian for 8GB SD Card - No reader, just USB
Posted: Fri May 04, 2012 8:25 am
by Airstream
Seems this should be easier, but I created the 2Gb Debian Rpi image using Windows tools Win32DiskImager to an 8GB SD card. I now want to resize the partition to make use of all 8GB. I have a separate machine running UBuntu which has an internal OEM card reader, which connects into a USB port. When I insert the SD card into the card reader it is recognised as /media/95F5-0D7A, but not as /dev/sdd as per the 'Easy SD card Setup' section. Two file systems are showing on the SD card, about 80mb and 2gb.
Do I need to start again and just re-write the SD image solely under Linux, or is there al alternative process to adjust the partition similar to using gparted? I also put the SD card into a USB adapter and same story.
Posted: Fri May 04, 2012 9:27 am
by TheTap
Try this on your Ubuntu machine:
Open a terminal and type - mount | grep 95F5-0D7A
it should come up with a line something like - /dev/sdd1 on media/95F5-0D7A
Posted: Fri May 04, 2012 9:45 am
by bredman
Your problem is caused by Ubuntu trying to hide the complexity of the file system. It's just trying to help...
Open a command terminal (Ctrl-Alt-t) in Ubuntu and enter the command
df -h
This will give you a list of all the file systems and their sizes (the -h option shows the human-friendly sizes like MB and GB).
Posted: Fri May 04, 2012 11:48 am
by Airstream
So here is what I have following these commands. The resize option does not look  like what is given in the guide although it is showing /dev/sdb1 as the FS.
linux@Ubu9:~$ df -h
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda1             178G   18G  152G  11% /
none                 1001M  252K 1001M   1% /dev
none                 1007M  180K 1006M   1% /dev/shm
none                 1007M  352K 1006M   1% /var/run
none                 1007M     0 1007M   0% /var/lock
/dev/sdb2             1.6G  1.2G  298M  80% /media/18c27e44-ad29-4264-9506-c93bb7083f47
/dev/sdb1              75M   28M   47M  37% /media/95F5-0D7A
linux@Ubu9:~$ mount | grep 95F5-0D7A
/dev/sdb1 on /media/95F5-0D7A type vfat (rw,nosuid,nodev,uhelper=udisks,uid=1000,gid=1000,shortname=mixed,dmask=0077,utf8=1,showexec,flush)
linux@Ubu9:~$ sudo parted /dev/sdb1
GNU Parted 2.3
Using /dev/sdb1
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) unit chs
(parted) print
Model: Unknown (unknown)
Disk /dev/sdb1: 9,143,5
Sector size (logical/physical): 512B/512B
BIOS cylinder,head,sector geometry: 9,255,63.  Each cylinder is 8225kB.
Partition Table: msdos
Number  Start  End  Type  File system  Flags
(parted)
.... and this is where it ends. Next step?
Posted: Fri May 04, 2012 11:56 am
by Joe Schmoe
Note: /dev/sdb1 is the "FAT" (aka, /boot) partition - where the blob and stuff are.
/dev/sdb2 is the Linux partition (presumably, this is the one you want to "resize")
Posted: Fri May 04, 2012 12:05 pm
by Airstream
Okay - This is what I have as the 1.6GB partition
linux@Ubu9:~$ sudo parted /dev/sdb2
GNU Parted 2.3
Using /dev/sdb2
(parted) unit chs
(parted) print
Disk /dev/sdb2: 202,177,38
BIOS cylinder,head,sector geometry: 202,255,63.  Each cylinder is 8225kB.
Partition Table: loop
Number  Start  End         File system  Flags
1      0,0,0  202,177,38  ext4
(parted)
... but I dont have 3 entries so work out the resize?
(Oh and the Rpi Model B arrived today!)
Posted: Fri May 04, 2012 12:36 pm
by bredman
It is not clear what your current problem is because I cannot understand "… but I dont have 3 entries so work out the resize?". But here is some useful info anyway...
To be able to repartition sdb2, you will probably need to unmount it from Ubuntu. You can right-click in the file manager and unmount or enter the command
sudo umount /dev/sdb2
If you want to see the full size of the disk, use the command
sudo fdisk /dev/sdb
Use 'q' to quit fdisk.
To change the size of /dev/sdb2 in parted use the command
(parted) resize 2 xxxxx yyyyy
where xxxx is the original start of sdb2 (you may not change that) and yyyy is the end of the disk.
Posted: Fri May 04, 2012 12:51 pm
by grumpyoldgit
I am even more confused. Why on earth doesn't the OP use gparted and then he could see what he was doing?
Posted: Fri May 04, 2012 1:26 pm
by Airstream
Please view link http://elinux.org/RPi_Easy_SD_Card_Setup and see section ' Manually resizing the SD card partitions (Optional)'
The example showing 3 partitions in the table (which I do not have)$ sudo parted /dev/sdd
(parted) unit chs
(parted) print
Disk /dev/sdd: 121535,3,31
BIOS cylinder,head,sector geometry: 121536,4,32. Each cylinder is 65.5kB.
1 16,0,0 1215,3,31 primary fat32 lba
2 1232,0,0 26671,3,31 primary ext4
3 26688,0,0 29743,3,31 primary linux-swap(v1)
Thanks for advice...When I use the Ubuntu Disk Utility I see a 79MB FAT, 1.7GB ext4 and a 200MB swapfile.
And 6GB free space.
Now I see what is required
linux@Ubu9:~$ sudo umount /dev/sdb1
linux@Ubu9:~$ sudo umount /dev/sdb2
linux@Ubu9:~$ sudo umount /dev/sdb3
linux@Ubu9:~$ df -h
none 1007M 412K 1006M 1% /dev/shm
GNU Parted 2.3
Using /dev/sdb
(parted) unit chs
(parted) print
Model: Generic USB SD Reader (scsi)
Disk /dev/sdb: 119359,3,31
BIOS cylinder,head,sector geometry: 119360,4,32. Each cylinder is 65.5kB.
(parted) parted move 3 116303,0,0
End? [119358,3,31]?
(parted) rm 2
(parted) mkpart primary 1232,0,0 116302,3,31
(parted) quit
Information: You may need to update /etc/fstab.
linux@Ubu9:~$ sudo e2fsck -f /dev/sdb2
[sudo] password for linux:
e2fsck 1.41.12 (17-May-2010)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
/lost+found not found. Create<y>? yes
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/sdb2: ***** FILE SYSTEM WAS MODIFIED *****
/dev/sdb2: 59389/101920 files (0.0% non-contiguous), 310435/407040 blocks
linux@Ubu9:~$ sudo resize2fs /dev/sdb2
resize2fs 1.41.12 (17-May-2010)
Resizing the filesystem on /dev/sdb2 to 1841136 (4k) blocks.
The filesystem on /dev/sdb2 is now 1841136 blocks long.
This now shows a 6.7GB #2 resized partition.
