penguintutor
Re: HDMI to VGA
Thu May 10, 2012 7:48 pm
I've experimented a bit more.
I haven't tried every mode, but I've tried over a dozen and I've only found two settings that work with this particular adapter.
hdmi_mode=4
puts the adapter into 720p60 which shows up in X as a very poor 576x416
hdmi_mode=16
puts the adapter into 1080p60, which gives a slightly improved 960x704
This is far less than the adapter is capable of - as in my Kubuntu laptop I can drive the HDMI cable up to 1366 x 768, also if I use a HDMI to DVI cable on the Pi then I get a resolution of 1366 x 768.
penguintutor
Re: HDMI to VGA
Fri May 11, 2012 6:16 am
I have now finally got it working at a good resolution.
1584 x 954 for my particularly adapter and monitor combination.
Rather than changing the hdmi_mode, instead change the hdmi_drive to the DVI option.
In /boot/config.txt - remove the previous entries for hdmi_mode and instead insert the following:
hdmi_drive=1
rocketero
Re: HDMI to VGA
Thu Feb 07, 2013 8:39 am
thanks for your input, it worked for me with
hdmi_driver=2
and now I have 1600x900 video screen.
