Re: detailed documentation of GPIO ?
Posted: Wed May 02, 2012 2:20 am
Hello.
Before I buy a R-Pi, I want to know if it can do what I need.
All I want is to read the fully detailed documentation of the GPIO. Hardware side (how the output have been designed, if they are tristate or not, high impedance, pin count, available features, and ... how to control them from Linux. For example, I know that good quality bit forging in almost impossible under Linux due to the poor Linux VM (many things work way better under DOS; example, it's impossible under Linux to generate PWN at a rate higher than the VM rate; while DOS granilosity can come down to the bus freq !!! )
I personally find the legacy parallel port on PC pretty much complex to use to play with relays; and sound card is usually the best analog input. And computers hardly have analog outputs.
I want to know what can be done with the GPIO at hardware side, and how complex it is at software side.
- digital vs analog
- inputs and outputs
- pin count
- features for each pin
I did not find any doc on this website; so, I will probably need a user to email me the CD content.
Finaly, who has stock in Europe (France) ? The french Farnell says to be out of stock.
- digital vs analog
- pin count
