Analog Video Output on Raspbery
Posted: Mon Aug 26, 2013 12:53 pm
by caporeira
Have maybe Raspberry Pi analog video output ?
Or maybe someone know how to cheep convert digital to analog signal ?
Re: Analog Video Output on Raspbery
Posted: Mon Aug 26, 2013 8:36 pm
by mahjongg
the RCA output of the PI will output analog video, if you do not connect a HDMI device.
Posted: Tue Aug 27, 2013 9:51 am
by caporeira
Thank you for your answer.
I forgot add to my ask, I want to have Analog RGB signal, how do I make it ?
Posted: Tue Aug 27, 2013 10:09 am
by redhawk
You will need a HDMI to RGB converter box (component or scart depending on your video equipment).
Make sure it comes with an external PSU since the Pi isn't designed to power devices directly via the HDMI port.
Richard S.
Posted: Tue Aug 27, 2013 10:40 pm
by caporeira
Can you recommend the cheapest solution to have Analog RGB video signal ?
Posted: Wed Aug 28, 2013 10:26 am
by redhawk
There is no cheap solution converting HDMI to analogue video is quite a complicated process.
To be honest I don't see any benefit for converting HDMI to RGB when the resolution is no better than composite video.
Granted composite isn't great but if your watching videos on and old CRT type TV the image quality should be more than adequate.
Richard S.
