Page 1 of 2
Re: Arch Linux Enable SSH
Posted: Tue May 01, 2012 6:05 pm
by benzeman
How do I enable (read: get from new SD card image to logged) SSH for the Arch Linux image? I've taken a look around the FAT partition for a folder called boot, but no luck, and obviously it's not enabled by default!
Chears,
Ben
Posted: Tue May 01, 2012 6:45 pm
by spennig
If it's not already there, install the openssh package:
# pacman -S openssh
Then add it to the DAEMONS list in /etc/rc.conf, so it starts on boot:
DAEMONS=( .... sshd ....)
To start it immediately without reboot.
# rc.d start sshd
Posted: Tue May 01, 2012 6:58 pm
by benzeman
I did that, but still can't SSH into the pi. Running rc.d start sshd comes up with: Starting Secure Shell Daemon [FAIL]. That's bad, isn't it...
If it helps, I've already done a pacman -Syu.
Posted: Tue May 01, 2012 7:16 pm
by pepedog
Try new images
http://downloads.raspberrypi.o.....4-2012.zip
http://downloads.raspberrypi.o.....2.zip.sha1
http://downloads.raspberrypi.o.....ip.torrent
Default login: root/root
Posted: Tue May 01, 2012 7:19 pm
by spennig
Certainly sub-optimal.
As root, what happens when you run the startup command manually?# /usr/bin/ssh-keygen -A# [[ -d /var/empty ]] || mkdir -p /var/empty
# /usr/sbin/sshd
Posted: Tue May 01, 2012 7:29 pm
by benzeman
downloading the images now
Posted: Tue May 01, 2012 8:02 pm
by benzeman
Ok, so I don't get any HDMI output (using a HDMI to DVI cable) with those images... weird...
Posted: Tue May 01, 2012 8:17 pm
by dom
Do you know if it's booting? Can you try a different display?
Do you get HDMI output with latest debian image?
Posted: Tue May 01, 2012 8:26 pm
by benzeman
I get HDMI output with debian 19-04-12 – I''ll try re-imaging my (arch) SD card…
ps - for the avoidance of doubt I have 2 SD cards, one I'm currently using for debian/demo, and one for arch/webserver. This is (obviously) the arch/webserver card I'm putting arch on.
Posted: Tue May 01, 2012 8:44 pm
by benzeman
nope, a re-image and arch 29-04-12 still won't give hdmi out :'(
Posted: Tue May 01, 2012 8:51 pm
by dom
I don't think anything HDMI related has changed since debian 19-04-12.
Do you have a config.txt file on debian card?
Do you have a config.txt file on arch card?
Posted: Tue May 01, 2012 8:53 pm
by benzeman
config on arch:hdmi_mode=19
#arm_freq=800
disable_overscan=1 no config file on debian...
Posted: Tue May 01, 2012 8:54 pm
by Tass
Very weird.  I've only used 19-04-12, but it seemed fine.  When you boot up are you getting the red Power AND the green OK light?
Posted: Tue May 01, 2012 8:58 pm
by benzeman
red on all the time, green flickers (I assume red is power, green is load?)
Posted: Tue May 01, 2012 9:25 pm
by dom
#arm_freq=800
So arch doesn't work. debian works:
Well the obvious suggestion is to remove the config file from arch...
Posted: Tue May 01, 2012 9:43 pm
by Tass
OK - this probably won't help you much, but I've just downloaded & installed the latest image (29-04-2012), applied it to my SD card (Sandisk 2GB MicroSD - unknown class) and plugged in my network cabled & power.  Once booted up (took about 60s the first time) I found the IP Address & connected via SSH (using Bitvise Tunnilier) without any problems.  No adustments necessary.  I'll try plug it into my TV when I can wrestle control back....
Sorry it's not much help
Posted: Tue May 01, 2012 10:11 pm
by pepedog
First boot it generates unique certs.
try deleting /boot/config.txt, when you get a chance
Posted: Tue May 01, 2012 10:49 pm
by Tass
Yes, green's load as I understand it, so at least you know it's booting up or doing something.  For what it's worth, HDMI works for me without any modifications, and I have the config file - same content as above:
hdmi_mode=19
#arm_freq=800
disable_overscan=1
Sounds quite specific to your setup - the way your TV picks up your Pi when running Arch maybe?  Hopefully simply removing that config file will sort it out.  Not sure what other hmi_mode options there are?
Posted: Wed May 02, 2012 5:24 am
by benzeman
That worked - I thought arch needed config.txt because 19-04-12 had it, but works fine without!
Posted: Wed May 02, 2012 5:30 am
by benzeman
Well, just tried SSH-ing without any modifications, and got a big fat error (connection refused)...
Posted: Wed May 02, 2012 7:02 am
by benzeman
Will try this evening with the laptop I'm using and the Pi plugged into the same router.
Posted: Wed May 02, 2012 10:17 am
by pepedog
Maybe IP address changed?
Posted: Wed May 02, 2012 10:23 am
by Tass
Yes, good point - I did notice that every time I booted up the Arch image it had a completely different IP.  I have to keep using something like Advanced IP Scanner to get the IP every time.
Posted: Wed May 02, 2012 11:13 am
by benzeman
Is there a way to check the IP arch has within arch? I used the bt home hub (v2.0a if it helps), and it reported the IP stayed the same.
Posted: Wed May 02, 2012 11:26 am
by bredman
I don't know about Arch, but the standard Linux command should be
hostname -I
