Re: Power from TV?
Posted: Fri Apr 27, 2012 1:42 pm
by abrown
When I finally get my RasPi I'm hoping to use the 5v power supply that my TV provides via it's UHF antenna connection (I think it does this for TV mast signal boosters). I want to do this as I only have 1 mains power socket behind my TV and don't want to have any more mess there (it's wall mounted).
Has anyone managed to do this? I'm guessing if the TV can provide enough current @ 5v then I should just be able to hack together a UHF connector and an old micro USB connector. Any thoughts?
Re: Power from TV?
Posted: Fri Apr 27, 2012 1:55 pm
by bredman
Please measure the voltage carefully, you need a well-regulated voltage between 4.85v and 5.25v.
You will need to build your own filter to extract the DC component. DO NOT connect the UHF directly to the RPi.
It's very strange to see 5v on a UHF connector. Most boosters use 12v or 24v.
All in all, it's very risky for little benefit.
Re: Power from TV?
Posted: Fri Apr 27, 2012 2:19 pm
by cnxsoft
If your TV is new enough to have a USB connector then your problem should be solved.
Powering the Pi using the antenna connection seems risky to me.
Re: Power from TV?
Posted: Fri Apr 27, 2012 11:03 pm
by mahjongg
There is a big risk that the 5V isn't stabilized, and the voltage fluctuates heavily under load, which makes it totally unuseable for the R-PI which needs exactly (to 5% precise) 5 Volt.
At least test if the unloaded voltage, and the loaded with 750mA voltage doesn't vary beyond 4.75 and 5.25 volt.
Re: Power from TV?
Posted: Sat Apr 28, 2012 9:10 am
by rew
It is difficult to measure properly. If the voltage drops to 3V for a milisecond, then your raspberry pi will crash. So if you measure a proper 5V without load and with load, you might still run unto power problems.
