trevorjdaniel
Boot to Root and Run a Script?
Sun Aug 04, 2013 2:36 pm
I have been trying to work out how to
1. Stop my pi booting into LXDE.
2. Boot to a command prompt as root.
3. Run a python script.
I have fallen at the first hurdle. :oops:
I found a posting that says run "sudo raspi-config" and in there is an option to configure whether the pi boots to LXDE - happy days! So, I told it NOT to boot to LXDE. But, now when the pi boots, it automatically runs raspi-config at startup.
I want to boot the pi to a command prompt as root, then run a python script.
Can anyone help please?
Trev
itimpi
Re: Boot to Root and Run a Script?
Sun Aug 04, 2013 5:03 pm
When it runs raspi-config, just tell rasp-config you are finished. That should stop it running next time.
Joe Schmoe
Sun Aug 04, 2013 6:21 pm
itimpi wrote:When it runs raspi-config, just tell rasp-config you are finished. That should stop it running next time.
That is certainly good advice, but it begs the question: Why (how) did it get into "auto-run-on-next-boot" mode in the first place? I saw nothing in the OP's description that indicated that it should do that. This makes me wonder if something else is going on - implying that the simple "do it and it will reset itself" advice is maybe not sufficient.
trevorjdaniel
Sun Aug 04, 2013 6:30 pm
it certainly does!!! thanks.
id been just hitting escape as all other settings seemed to save on the fly.
now to crack question 3.
trev
itimpi
Sun Aug 04, 2013 7:26 pm
If you want something to be run on starting the system put the command into /etc/rc.local. If you want the system continue to a log in prompt then add an & character at the end of the line.
Joe Schmoe
Sun Aug 04, 2013 8:10 pm
itimpi wrote:If you want something to be run on starting the system put the command into /etc/rc.local. If you want the system continue to a log in prompt then add an & character at the end of the line.
That is one of the many ways to do it - and about the most error-prone, especially for a new user of Unix/Linux.
Basically, there is a 2x2 matrix here - with skill of user on one axis, and whether this is just some odd daemon (like, say, the sshd process), or the main, primary app/usage of the Pi.
In only one of these boxes (high skill, odd daemon) is rc.local a good idea.
Return to “Beginners”
