Is this possible? I've got my Raspberry PI hooked up to my desktop, and I've shared my internet connection, however I can't get online.
I can ping the router (192.168.1.1) but it doesn't get any further than that.
Any advice?
Re: Internet Connection Sharing with Windows 7 Machine
Any advice?
of course it is poosible
Check if DNS is working on the Pi, run this command:
dig google.com
if is doesn't resolve google.com into a couple of IPv4 addresses, then insert the IPv4 address of minimum 1 DNS server into /etc/resolv.conf
Changes to /etc/resolv.conf has effect immediately.
Googles public DNS server IPv4 adresses are 8.8.8.8 and 8.8.4.4
Any advice?
dig google.com
Ahh cheers, working!
- RaTTuS
- Contact: Twitter YouTube
or you can use the opendns servers 208.67.222.222 208.67.220.220
Covfefe
Covfefe
I did have a very strange issue with this. Depending on which wireless adapter my win7 pc was using to access my home wireless, I was either able or unable to run: sudo apt-get update on the RPi. One adapter caused me to consistently get stuck waiting for headers to download, while the other worked fine...
Internet Connection Sharing (a Windows thing) is definitely a mixed bag. It can stop working for any number of seemingly arbitrary reasons (or for no reason at all). It has always been thus, for the many years that I've been using it (off and on - never as the basis of an ongoing system).
I would imagine that if you want to do apt-get update or any other thing requiring an Internet connection from your Pi, you should so something like:
ping google.com && apt-get update
I was always annoyed that it forced me to use a specific IP address for the interfacing through which the sharing was being done rather than let me manually set it to whatever I pleased.
Dear forum: Play nice
Right. It is hardcoded to use 192.168.1.1 for its end of the connection - and 192.168.1.* for the clients.
I get the impression that it was added to Windows as a quick "one-off", possibly by an intern or something, and was never really finished. Orphaned, as they say.
ICS is more of a legacy application nowadays, "bridging" adapters is the way to go.
I'll set a minimal example.
Windows 7 machine connected to internet through router via wifi.
Ethernet hub connects win 7 machine, raspberry Pi (and other devices but let's keep it simple).
First of all open "Network and sharing center" on the win7 machine.
Select "Change adapter settings"
select the wifi adapter and the ethernet adapter.
right click one of the adapers and select "Bridge Connections".
A new adapter appears called "Network bridge".
right click on this adapter and select properties.
Edit the IPv4 settings to your preferance, lets use a 10.0.0.0 address range.
(to show that the 192.168.1.* restriction is avoided.)
so we'll have router address 10.0.0.1 win7 machine at 10.0.0.2 and the Pi at 10.0.0.3
so for the bridged adapter (win7 machine) :-
ip address= 10.0.0.2
netmask=255.0.0.0
gateway=10.0.0.1
preferred Dns Server=10.0.0.1
let's now setup the Pi
edit /etc/network/interfaces (I prefer nano but use the editor of your choice).
iface eth0 inet static
address 10.0.0.3
netmask 255.0.0.0
gateway 10.0.0.1
then edit /etc/resolv.conf for DNS
nameserver 10.0.0.1
then restart your network
/etc/inet.d/networking restart
netmask=255.0.0.0
gateway=10.0.0.1
address 10.0.0.3
netmask 255.0.0.0
gateway 10.0.0.1
nameserver 10.0.0.1
Dendennis - would it work with an ethernet crossover cable instead of an ethernet hub?Windows 7 machine connected to internet through router via wifi.
Cheers
