Hi all,
I just wanted to confirm before I buy a passive USB hub, that it will work with the Raspberry Pi if the item being plugged in by USB is powered.
I'm hoping to plug two mains powered USB hard drives into the same USB socket on the Pi as the other socket is being used for a USB printer.
I'd prefer a passive USB hub to save another device from being plugged into the wall, which seems a bit wasteful!
Can you confirm that a mains powered hard disk wouldn't draw much (or any) power from the USB so a hub would work?
Thanks,
Pez
P.s. I have searched the forum, but couldn't find a detailed post on passive USB hubs, usually the response is: just buy a powered one.
