Wed Jul 31, 2013 4:42 pm
It is handy to know the difference between a passive Hub & Active Hub
A Passive hub drawers power from the Pi power supply ,This will divert
Power from the Pi to drive the signal. If you have several thing plugged
In to your hub the current needed to drive the signals will accumulate.
Diverting to much current from the Pi will not allow the Pi to function
Properly.
A Active hub have built in Buffer stages, this will allow the Pi signals
To draw the drive current from the active hub power supply
And not draining the Pi power
All signals require power High or Low to drive them throe the input resistance they will meet
Advice Use A powered Hub
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
