Re: Debian Terminal Colors - How?
Posted: Fri Apr 20, 2012 5:47 pm
by Britaniola
I'd like to have the non-GUI terminal show colors for directories, prompts and the like. How do I go about changing from the default Linux term to something like xterm-color?
Bill
BTW...before I get the usual RTFM replies, I've tried looking on the net, using the package manager to DL xterm, Googling it, R'ingTFM, etc.
Please be kind and feed the n00bs!
Posted: Fri Apr 20, 2012 6:19 pm
by walney
Prolly manage it by typing:
export TERM=ansi
at the command prompt
Posted: Fri Apr 20, 2012 6:34 pm
by Britaniola
export TERM=ansi
Thanks for the answer but it didn't work.
Bill
Posted: Fri Apr 20, 2012 6:37 pm
by jojopi
There is nothing wrong with the TERM setting.  The issue is that /home/pi in the distributed image starts out completely empty, without the usual dot files.
To fix it run the following command as user pi, and then log back in.cp -a /etc/skel/.??* ~/
Posted: Fri Apr 20, 2012 6:47 pm
by Britaniola
You nailed it! Thanks. I never thought of the missing files in the user home.
"I see colors."
Posted: Fri Apr 20, 2012 6:50 pm
by walney
export TERM=ansi
D'oh... must engage brain before mouth.
Posted: Wed Jul 23, 2014 11:55 am
by sanjeev4cs
i had done by copy my .bashrc in linux system(ubuntu) , which have already enabled color terminal .
1. step
/* for precaution : - make back up of .bashrc in Raspberry */
[email protected] : cp .bashrc .bashrc.backup
2. step
/* copy .bashrc from your system(ubuntu) to raspberry pie
scp .bashrc [email protected]:/root/
3. step
Reboot
