Britaniola
Re: Debian Terminal Colors - How?
Fri Apr 20, 2012 5:47 pm
I'd like to have the non-GUI terminal show colors for directories, prompts and the like. How do I go about changing from the default Linux term to something like xterm-color?
Bill
BTW...before I get the usual RTFM replies, I've tried looking on the net, using the package manager to DL xterm, Googling it, R'ingTFM, etc.
Please be kind and feed the n00bs!
walney
Fri Apr 20, 2012 6:19 pm
Prolly manage it by typing:
export TERM=ansi
at the command prompt
Britaniola
Fri Apr 20, 2012 6:34 pm
export TERM=ansi
Thanks for the answer but it didn't work.
Bill
jojopi
Fri Apr 20, 2012 6:37 pm
There is nothing wrong with the TERM setting.  The issue is that /home/pi in the distributed image starts out completely empty, without the usual dot files.
To fix it run the following command as user pi, and then log back in.cp -a /etc/skel/.??* ~/
Britaniola
Fri Apr 20, 2012 6:47 pm
You nailed it! Thanks. I never thought of the missing files in the user home.
"I see colors."
walney
Fri Apr 20, 2012 6:50 pm
export TERM=ansi
D'oh... must engage brain before mouth.
sanjeev4cs
Wed Jul 23, 2014 11:55 am
i had done by copy my .bashrc in linux system(ubuntu) , which have already enabled color terminal .
1. step
/* for precaution : - make back up of .bashrc in Raspberry */
[email protected] : cp .bashrc .bashrc.backup
2. step
/* copy .bashrc from your system(ubuntu) to raspberry pie
scp .bashrc [email protected]:/root/
3. step
Reboot
