scratchuser
motion failing to start as daemon or interactive
Wed Jul 10, 2013 9:37 pm
I am trying to get a webcam working with my new Pi but am having problems.
I am using these instructions: http://pingbin.com/2012/12/raspberry-pi ... er-motion/ but when it comes to running starting the daemon, I get this:
[email protected] ~ $ sudo service motion start
[warn] Not starting motion daemon, disabled via /etc/default/motion ... (warning).
If I just do motion start, I get this:
[email protected] ~ $ motion start
[0] could not open configfile /etc/motion/motion.conf: Permission denied
[0] Not config file to process using default values
[0] Motion 3.2.12 Started
[0] ffmpeg LIBAVCODEC_BUILD 3482368 LIBAVFORMAT_BUILD 3478785
[1] Thread 1 started
[1] cap.driver: "spca561"
[1] cap.card: "Camera"
[1] cap.bus_info: "usb-bcm2708_usb-1.3.2"
[1] cap.capabilities=0x85000001
[1] - VIDEO_CAPTURE
[1] - READWRITE
[1] - STREAMING
[1] Config palette index 8 (YU12) doesn't work.
[1] Supported palettes:
[1] 0: S561 (S561)
[1] 1: GBRG (GBRG)
[1] Unable to find a compatible palette format.
[1] ioctl (VIDIOCGCAP): Inappropriate ioctl for device
[1] Could not fetch initial image from camera
[1] Motion continues using width and height from config file(s)
[1] Resizing pre_capture buffer to 1 items
^C[1] Thread exiting
[0] Motion terminating
[email protected] ~ $ ^C
Any idea what else I need to do to get this working? Particularly as a daemon?
--- Alistair.
SirLagz
Re: motion failing to start as daemon or interactive
Thu Jul 11, 2013 8:25 am
This line should give you an idea...
Check what's in /etc/default/motion
^ that is from starting motion as a normal user.
If you start it as root, what happens ?
scratchuser
Thu Jul 11, 2013 7:37 pm
Hmm...
Summary: Service is now working but cannot connect with web-browser. Please see the end for the current situation.
Here's a session trying to start it with sudo:
[email protected] ~ $ sudo motion start
[0] Processing thread 0 - config file /etc/motion/motion.conf
[0] Exit motion, cannot create process id file (pid file) /var/run/motion/motion.pid: No such file or directory
[0] Motion going to daemon mode
[email protected] ~ $ sudo mkdir /var/run/motion
Sort of implies it is running as a daemon anyway, once I had created the /var/run/motion directory. But explicitly doing so still gets:
Interestingly, I just realised that the file I have been editing is /etc/motion/motion.conf, not /etc/default/motion. So...
[email protected] ~ $ more /etc/default/motion
# set to 'yes' to enable the motion daemon
start_motion_daemon=no
So I have set that to 'yes' (could I also just delete the file I wonder? Anyway, now, I get:
[ ok ] Starting motion detection daemon: motion.
Actually, I had to stop it first since my interactive attempts had already started it. But it seems now to work! Thanks for the pointers.
Now the current situation...
So the service/daemon is running. But when I try to connect to it at 192.168.1.100:8081, I get
Unable to connect
Firefox can't establish a connection to the server at 192.168.1.100:8081.
If I try port 8080, I get
Motion 3.2.12 Running [1] Threads
0
So something is running but I still get nothing on port 8081. Any further suggestions? The full motion.conf is quite large so I have attached it as motion.txt.
--- Alistair.
SirLagz
Fri Jul 12, 2013 1:34 am
Are you accessing the motion stream from the Pi itself ?
Some people have had issues accessing the stream from the Pi.
Modify /etc/motion/motion.conf and allow other hosts to connect.
Change lines
webcam_localhost on
control_localhost on
to
webcam_localhost off
control_localhost off
to allow other hosts to connect.
scratchuser
Fri Jul 12, 2013 7:25 pm
Certainly getting there. control_localhost was off but webcam_localhost was on. I now have a little square in my browser window. Unfortunately, it is plain grey with a caption saying
UNABLE TO OPEN VIDEO DEVICE
SINCE 2013-07-12 19:15:31
[email protected] ~ $ lsusb
Bus 001 Device 007: ID 046d:092f Logitech, Inc. QuickCam Express Plus
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
So the PI can see the QuickCam, but I have not explicitely pointed motion at it. Is that in the conf file somewhere? I will have a look later.
--- Alistair.
scratchuser
Fri Jul 12, 2013 8:18 pm
Actually, it turns out that I have pointed the motion at the camera:
# Videodevice to be used for capturing  (default /dev/video0)
# for FreeBSD default is /dev/bktr0
videodevice /dev/video0
and that device file does exist. Is the QuickCam not compatible with the Raspberry PI? Is there any way of confirming that it works?
--- Alistair.
scratchuser
Sat Jul 13, 2013 11:04 pm
Just tried with fswebcam:
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
No input was specified, using the first.
Adjusting resolution from 640x480 to 352x288.
--- Capturing frame...
Captured frame in 0.00 seconds.
--- Processing captured image...
Setting output format to JPEG, quality 99
Writing JPEG image to 'test1.jpg'.
This results in a very low-res, grainy image, just about recognisable as my lounge. So the webcam does work after a fashion. Any ideas why motion can't open it? Is it just too old and crap?
--- Alistair.
SirLagz
Sun Jul 14, 2013 12:13 pm
Quite possible that the webcam is just too old...
Al6lo6co6
Fri Jul 19, 2013 1:27 am
I am also trying to run a webcam server. I have everything running the cam light is on and motion service is running how ever i cannot connect from another browser. I am using Ethernet not wireless and I have already set localhost = off what am I missing or is it a problem with my router?
Cole_Trickle
Wed Nov 13, 2013 1:00 am
was there ever a solution to this? I am running set up with PiCam and get the same "unable to open /dev/video0" in my motion webbrowser on port8081. I can capture using raspicam though. so I know the cam works.
ask me about Cisco....
henickr
Mon Nov 25, 2013 11:57 pm
you need to download a special version of motion optimized to use on raspberry pi.
the device for a built in raspi cam module is /dev/vchiq not /dev/video0
nalin
Sat Nov 30, 2013 7:52 am
hi
i want to write a daemon to start video capture and send to mail
can anybody help
ChadRpi
Sat Nov 30, 2013 1:34 pm
Here is a tutorial that I made to setup and use motion.
http://www.youtube.com/watch?v=D537dG-ndRk
It definitely works if you follow it.
Let me know if it helps :)
gerombo
Sat Dec 27, 2014 11:38 pm
with a similar Logitech QuickCam I made a bit of progress on my model B with raspbmc kernel 3.12.31
I also noticed the following error messages about the missing palette.
My webcam:
[email protected]:~$ lsusb | grep Logit
i found a hint here:
http://www.lavrsen.dk/foswiki/bin/view/ ... x28x191448
basically you have to
sudo apt-get install -y libv4l-0
and
find / -iname "*libv4l*" 2>/dev/null
to find the shared object library
/usr/lib/arm-linux-gnueabihf/libv4l
for debugging you can now start motion in foreground with
sudo LD_PRELOAD=/usr/lib/arm-linux-gnueabihf/libv4l/v4l2convert.so motion
this works for a about a minute or two
[0] Thread 1 is from /etc/motion/motion.conf
[0] motion-httpd/3.2.12 running, accepting connections
[0] motion-httpd: waiting for data on port TCP 8080
[1] cap.bus_info: "usb-bcm2708_usb-1.3"
[1] - VIDEO_CAPTURE
[1] - READWRITE
[1] - STREAMING
[1] Test palette YU12 (320x240)
[1] Using palette YU12 (320x240) bytesperlines 320 sizeimage 115200 colorspace 00000008
[1] found control 0x00980900, "Brightness", range -128,127
[1]     "Brightness", default 0, current 0
[1] found control 0x00980903, "Hue", range 1,127
[1]     "Hue", default 64, current 64
[1] found control 0x00980910, "Gamma (software)", range 500,3000
[1]     "Gamma (software)", default 1000, current 1000
[1] found control 0x00980911, "Exposure", range 1,2372
[1]     "Exposure", default 700, current 700
[1] found control 0x00980912, "Auto Gain (software)", range 0,1
[1]     "Auto Gain (software)", default 1, current 1
[1] found control 0x00980913, "Gain", range 0,255
[1]     "Gain", default 63, current 63
[1] mmap information:
[1] frames=4
[1] 0 length=16777216
[1] 1 length=16777216
[1] 2 length=16777216
[1] 3 length=16777216
[1] Using V4L2
[1] Started stream webcam server in port 8081
[1] Resizing pre_capture buffer to 3 items
[1] File of type 8 saved to: /tmp/motion/01-20141227225526.swf
[1] File of type 1 saved to: /tmp/motion/01-20141227225525-00.jpg
[1] File of type 1 saved to: /tmp/motion/01-20141227225525-01.jpg
[1] File of type 1 saved to: /tmp/motion/01-20141227225526-00.jpg
[1] File of type 1 saved to: /tmp/motion/01-20141227225526-01.jpg
[1] File of type 1 saved to: /tmp/motion/01-20141227225527-00.jpg
[0] httpd - Read from client
[1] File of type 2 saved to: /tmp/motion/01-20141227225559-snapshot.jpg
after that motion is killed
libv4l2: error dequeuing buf: Input/output error
*** glibc detected *** motion: malloc(): memory corruption: 0x01e75300 ***
restarting motion results in a broken pipe. I had to unplug the webcam and plug it back in order to restart motion
libv4l2: error turning on stream: Broken pipe
[1] Error starting stream VIDIOC_STREAMON: Broken pipe
libv4l2: warning v4l2 mmap buffers still mapped on close()
Note: when preloading v4l1compat.so instead of v4l2convert.so the raspberry became unreachable and kernel messages piled up in /var/log/messages
Message from [email protected] at Dec 27 22:57:00 ...
 kernel:Internal error: Oops: 17 [#1] PREEMPT ARM
 kernel:Process CECAdapter (pid: 1053, stack limit = 0xd4e2e1b8)
 kernel:Stack: (0xd4e2fd0c to 0xd4e30000)
 kernel:fd00:                            462a1244 00000031 d4473f24 d4e2fd4c d4e2fd28
 kernel:fd20: c027e9c8 c027b774 00000031 46294ef4 00000031 0000c350 00000000 d4e2fe18
 kernel:fd40: d4e2fd9c d4e2fd50 c0043a94 c027e968 c0281348 c0280388 00000003 0000000a
 kernel:fd60: 20000013 00000000 c001a4c8 c005c7b4 2b1d020b 0000c350 00000000 d4e2fe5c
for completeness and inbound search queries, /var/log/messages when plugging in the webcam
Dec 27 21:58:28 raspbmc kernel: usb 1-1.3: new full-speed USB device number 7 using dwc_otg
Dec 27 21:58:28 raspbmc kernel: usb 1-1.3: New USB device found, idVendor=046d, idProduct=092f
Dec 27 21:58:28 raspbmc kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 27 21:58:28 raspbmc kernel: usb 1-1.3: Product: Camera
Dec 27 21:58:28 raspbmc kernel: usb 1-1.3: Manufacturer:
Dec 27 21:58:28 raspbmc kernel: gspca_main: spca561-2.14.0 probing 046d:092f
Dec 27 21:58:28 raspbmc kernel: input: spca561 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/input/input2
pzoco
Sun Feb 22, 2015 11:38 am
I have not read the entire thread. - I'll just answer what I've done to fix this:
Error is:
Change the file: /etc/init.d/motion
Find line: DEFAULTS=/etc/default/$NAME
Replace with #DEFAULTS=/etc/default/$NAME
Save and run "service motion start"
I have no idea if this is the best solution, but it was definitely a quick fix.
Cheers
rodmosh
Fri Mar 18, 2016 10:04 pm
It works in Ubuntu fine,
pzoco wrote:I have not read the entire thread. - I'll just answer what I've done to fix this:
Error is:
Cheers
Fruitybit
Mon Apr 11, 2016 5:48 pm
Well, I've been playing with this- trying to get the stream viewable. Lots of others seem to be having the same problem:(
From what I can see, when installing motion, another user is set up- motion- and added to a group- video. When I start motion, the first part of the dialog shows it's unable to open the configfile, so reverts to default settings ie no stream. I cannot amend the privileges of the file, nor find/amend the user 'motion' I'm sure there must be an easy way to get it working, it detects motion/saves files etc, so I know I'm half way there! Any ideas on the user privileges issue?
mrtumnus
Thu Apr 27, 2017 7:42 pm
Error is:
Cheers
No need to edit the init script. The default file itself contains the setting to fix this. Change the line in /etc/default/motion to:
start_motion_daemon=yes
Who is online
Users browsing this forum: No registered users and 37 guests
