frostforbes
apt-get via proxy
Mon Jul 08, 2013 10:29 pm
I am trying to use a Raspberry Pi at my school, and as I have no suitable monitors I am trying to do so headlessly. I've set a static IP (so I can find it on the network), netmask, gateway, etc. and can use ssh to remotely log in fine. The problem is that I also want to be able to VNC to the GUI. The school's access to the 'net is via eduproxy.bgfl.org:80 and apt-get can't connect to anything. I've looked online and many are suggesting that it is as simple as creating an apt.conf file with a line in it, but this seems to have no effect. When I try sudo apt-get install tightvncserver the screen tells me it is trying to connect to eduproxy but gives up. Anybody have any ideas of what I should try? Is there something I could try from the command line that will tell me I can successfully talk to the internet at all (pinging the net never works on any machine because of the way the proxy is set up)?
sprinkmeier
Re: apt-get via proxy
Tue Jul 09, 2013 9:30 pm
If you've had to set a static IP then chances are you're missing out on a whole lot of configuration that usuall arrives through DHCP (netmask, gateway etc.).
Can you ask your local IT staff? Not only are they in the best position to help, it's always polite to ask before connecting new equipment to someone elses network.
