Re: Wireless Keyboard/Mouse will it work?
Posted: Tue Apr 17, 2012 10:11 pm
by Guest
at the moment i only have a wireless keyboard/mouse, so will it work?
Or do i have to set it up with a usb one only?
Thanks.
Posted: Tue Apr 17, 2012 10:24 pm
by playmobot
I might be wrong here but as far as i know the mouse sends data to the receiver the receiver send that data as a normal mouse, so intern the computer does not know whether it wireless or wired. Same for keyboard.
Mouse ---> Receiver ---> Computer ---> Movement
Keyboard ---> Receiver ---> Computer ---> Letters/Numbers
^I got a little bit bored so i made a bad diagram^
Posted: Wed Apr 18, 2012 12:18 am
by Guest
Good news.
Used Lenovo n5902 wireless keyboard/mouse
Kingston 8GB Micro SD HC - Class 4
Power supply from a phone charger(cheap one)
Debian installed and is up and running.
Note
log in: pi
password: raspberry (i typed it but it wasn't showing but worked)
And then had to type startx
ps: a bit tooooooooo slow, Is it normal?
Posted: Wed Apr 18, 2012 6:37 am
by spurious
It's a $35 computer, not a $700 PC.
It performs adequately for the purpose it was designed, to teach kids how to program.
Personally I think it's not too shabby, considering all the optimisation that could be done to the OS hasn't been done yet.
Posted: Wed Apr 18, 2012 8:05 am
by Chris.Rowland
Thanks for the information about the wireless keyboard/mouse. It WBN if people could post what they have tried and how it works.
I've been looking at the Logitech MK260 set, it seems a reasonable compromise between cheap and reliable, has anyone tried it? Thanks for any feedback.
Posted: Wed Apr 18, 2012 9:28 pm
by berkobennie
I've ordered a Xenta Nano Wireless Multimedia 56 Key Keyboard anyone any experience of it?
Posted: Wed Apr 18, 2012 9:41 pm
by texy
It would of been wiser to ask before you ordered it, no?
T.
Posted: Thu Apr 19, 2012 8:28 am
by TopherBrink
Know it's not quite the same one but I got hold of the Logitech MK300 set yesterday and the keyboard and mouse both work fantastically well with the RPi.
Posted: Fri Apr 20, 2012 7:50 pm
by rmwebs
I'm using one of these and it works fine:
http://www.ebuyer.com/135103-x.....sb-kb-1000
One thing I will say is watch the power. If you find your wireless (or even wired) keyboard/mouse arent working or work intermittently, unplug everything else that uses USB.
Personally I'd recommend running all USB stuff through a GOOD, EXPENSIVE, BRANDED hub, Not a cheap, crummy eBuyer or eBay hub as these are NOT as powerful as they should be, and wont work properly as they dont provide enough power in most cases.
Posted: Fri Apr 20, 2012 9:33 pm
by Montala
That one looks interesting... does the touch-pad work OK with the Raspberry Pi also?
Posted: Fri Apr 20, 2012 9:41 pm
by rmwebs
Surprisingly, yes. I have to say that I wasnt expecting it to, but it works fine and is pretty well thought out. The left/right click buttons are on the left of the keyboard so you can keep your hands either side. I thought it would be a bit odd but its actually really nice to use. You can also 'tap' the touchpad to click - that seems to work fine on the Pi too.
I can only assume that the USB dongle effectively converts the keyboards input into a virtual native keyboard/mouse.
Posted: Fri Apr 20, 2012 10:00 pm
by Montala
Thanks for the quick reply... I saw the buttons in the picture, and rather liked the idea, so it is good to hear that it all works well.
Although I haven't got a Pi... yet, I am having fun sourcing some bits and pieces in readiness for its arrival, so I might just order one of these also!
Posted: Fri Apr 20, 2012 10:08 pm
by Berlingoman
