makem2
cron job
Tue Jul 02, 2013 9:27 am
I have this cron job:
crontab -e
0 5 * * * rsync -av --delete /media/USBHDD1/shares /media/USBHDD2/shares/
This backs up data from one drive attached to the PI to another attached drive.
I want to backup a folder on a PC on the network to USBHDD1 but can't work out what the syntax should be. Can someone assist please?
If I also want to backup a folder from another PC do I just add the same line again?
joebloggs
Re: cron job
Tue Jul 02, 2013 11:36 am
Might need a little more info..
What you are saying is mostly correct, if you wanted to run rsync to sync something else you can put a new line in the crontab file which is almost the same as the old one.
The difference would be that if you need to talk to a remote computer, that remote computer needs some way of talking back.
I think with rsync there are two ways, either running rsync or an SSH server on the PC, both of which would allow rsync to talk to the PC. Having rsync running on both machines would be best, but if you happen to have an SSH server on the PC already it should be able to use it.
The line in the crontab file would then be something like this:
0 5 * * * rsync -av USERNAME@HOST:SRC DEST
Where USERNAME is the login name, HOST is the hostname of the PC and SRC is the directory to be copied, DEST is the destination on the Pi.
Hope this helps,
post back with details of the system ruining on the PC if this explanation isn't detailed enough for you.
RaTTuS
Contact: Twitter YouTube
Re: cron job
Tue Jul 02, 2013 11:42 am
^WHS
but try it from the command line 1st
rsync -va user@src:/directory /directory
you will have to use
ssh-keygen -t rsa
ssh-copyid user@src
to enable you to login automagically
Covfefe
makem2
Re: cron job
Tue Jul 02, 2013 11:47 am
Thanks for your input.
I have rsync installed:
sudo apt-get install rsync
I am using the web page:
http://www.howtogeek.com/139433/how-to- ... ge-device/
to learn.
Both machines are Windows 7 and I would like to backup the profiles which have both been moved to D: drive.
RaTTuS
Re: cron job
Tue Jul 02, 2013 11:53 am
if you want to ssh into a windows machine then I think you need to add a ssh server
see
freesshd
putty may also have the option [not sure]
Covfefe
makem2
Re: cron job
Tue Jul 02, 2013 11:54 am
RaTTuS wrote:^WHS
ssh-keygen -t rsa
ssh-copyid user@src
^WHS - sorry don't understand this.
I understand the other terms but don't understand the logic behind them.
The Pi is always on.
Sorry, I am only 4 days into the learning curve.
makem2
Re: cron job
Tue Jul 02, 2013 1:09 pm
makem2 wrote:
RaTTuS wrote:^WHS
ssh-keygen -t rsa
ssh-copyid user@src
OH! WHAT HE SAYS!!!!
Where is my head????
makem2
Re: cron job
Tue Jul 02, 2013 5:15 pm
joebloggs wrote:Might need a little more info..
Hope this helps,
Can I run rsync on a Windows 7 PC?
I have putty and winSCP
I am not sure what you mean by SSH server
Can I not just do what I want using samba shares?
